well you heard..its getting spark now
..i fixed that today
..its a bright blue spark.
..anyway..it still isnt running...its getting gas and spark and not running..what could be the cause? my dad said low compression or not enough..im thinkin yea right its 12:1 !! and its pretty hard to push start it compared to the regular stock compression piston that was in there..i dont have a pullstarter...anyway..yea gas+spark= not running...whats the cause??..
) ..what gear u tryin to start it in?? with my friends 200x and his 12:1 it has to be in at least 3rd when cold..2nd when warmed up..well i just put it in the correct timing before i tried it..piston was at tdc cam lobes were down and it was all lined up..i cant figure it out and i gotta work tomarrow so ..ill figure out tuesday after school if i dont work..that 185 is truely a pos..i cant stand it anymore..i used to like workin on it..but now it seems everytime i do i strip a bolt hole or break something else..i need a different machine with a different engine..like a 2 stroker! ive never worked on one so it would probly jump my intrest alot..anyway..yea its just pissin me off..my light cam on also when i was pushing it...lol..it was gettin pretty bright to..5th gear is easiest to do it..1 wont move the tires with the standard 185s piston..2nd has trouble when being pulled by car/truck/atv to move them..tears stuff up..thats how my shifter return spring got broke..anyway it still shifts fine..3rd is ok and gets it revvin high..4th is good and 5th is easiest..but since u have a manual clutch then you should only do it in 3rd if you have to...with someone pushing or being towed..so itll start and you can bring the clutch in...anyway..yea somethin is wrong..i think it doesnt have enough compression but i torqued those bolts as hard as i could since it has the 12:1 o dont want it blowin gaskets..i mean it doesnt even try to start tho..it has spark and gas but doesnt even try...its gotta be timeing...i just fixed my exitor coil...had to re-solder the wiring on..after i did that i electrical tapend over the wire and solder..to help it stay..its gotta be the timing tho
