Thread: checking valves
    Mudder F er is offline At The Back Of The Pack Arm chair racerFirst time rider
    Miami, FL.
    151
    checking valves
    Can any one give me some instructions on how to check my valves 84 200s. Im on my 3rd cam, what can be the problem? I have clymer but I dont always understand what its saying nor do I have all the tools they ask for. Any help is appreciated. Thanks
    Mudder Fu@#er
    85 Auto 200X
    81 185s
    Aug 2004
    Ab Canada
    4,368
    http://www.3wheeler.org/dirtwheels/6...neupindex.html check that out for setting valves, as for wearing out 3 cams, when you pop the valve cap off, is there any oil there?...
    1985 Tri-Z-
    Miami, FL.
    151
    there is oil its circulating.
    Mudder Fu@#er
    85 Auto 200X
    81 185s
    Jul 2004
    Mud hill. close to water !
    3,658
    Your cam journals might be worn out, is there play in the cam ? is your timing chain tight as well ?
    things to consider i guess.
    Currently :
    What part of your cam is wearing out?? Lobes, journals?? Are the rockers and shafts getting oil and up to spec, are they adjusted to tight?? Is the valve binding in the guide??
    Miami, FL.
    151
    The cam lobes are wearing I am going to check the valves the cam chain seems fine. Timing is perfect.
    Mudder Fu@#er
    85 Auto 200X
    81 185s
