Results 1 to 12 of 12
Thread: 1976 ski doo tnt 440
    Jul 2004
    minnesota
    689
    ok my friend has a 1976 ski doo tnt 440 and he is about 245lbs and before i sold it to him it was a power house and would do ski stands and i could whip donuts and get it to fishtail, but when he rides it he has to give it 3/4 throttle all the time to even make it move with him on it, but i only weigh 137lbs but a jump from 137 to 245 can it make that much of a difference in the torque and stuff?, and before i sold it i put a new secondary clutch assembly , new belt, new brake pads, greesead all the boogies, installed new plugs, and put new coils and plug wires on it, and installed new piston rings and honed the cylinders, and greased the steering,and i know the brakes are NOT dragging the track spinnes freely, and it wont spin out at all with him on it, so is the problem just too much weight on it or what is going wrong cuz i feel sorta bad for hime that it doesnt move him to well, but it didnt do any of those things when i had it.
    my trikes:
    1983 honda atc 200x-k&n filter
    2002 yamaha raptor 660r, yoshimura slip on, prm grab bars
    1978 chevy nova, 454 v8, bds blower, 150hp shot of nitrous, full roll cage, a real power house.
    1991 chevy s10 4x4 350v8.
    1986 250sx
    YES its fast NO you cant ride it.
    hey, 2cycle, plugged muffler, bad gas, too rich, etc. hmmm, there are some things some people will never understand. changing brands of gas and/or mix.
    one cylinder is not enough!!
    Jul 2004
    minnesota
    689
    hey thankx i will tell him to check the muffler to see if it is plugged, and if it is plugged do i just use gas and just run the gs through it to clena it or what???
    my trikes:
    1986 250sx
    Aug 2004
    Ab Canada
    4,368
    sounds like he just needs to loose some weight! them 440s are ok but they aint got that much power......he IS mixing the gas right? ....
    1985 Tri-Z-
    Jul 2004
    minnesota
    689
    he hasnt even ran a full tank of gas out of the sled yet and the fuel ratio is 50:1 and he just got it on saturday,and when i sold it to him i mixed the gas 50:1 for him so he wouldnt have to do it for a while. and another thing is that i ordered a k&n air filter for it do ya think that will help at all???
    my trikes:
    1986 250sx
    rustbucket is offline At The Back Of The Pack Arm chair racerFirst time rider
    pentwater michigan
    180
    sounds like its only running on one lung or maybe it could use a carb cleaning. Those 440 tnt were actually pretty hot We had had a 75 with slides and it was fast.
    1980 trimoto 125 mods include a ripped seat broke fender and bent handle bars
    1981 trimoto 125
    1971 suzuki ts 185 it will spank a 200x
    1966 gmc 3/4 ton
    hey, I'd go over and ride it first, then go fron there. If it's the muffler, you have to burn it out, or hot tank it.
    Aug 2004
    Ab Canada
    4,368
    hotrod....have YOU tried riding it again?....im just thinking it cant haul his ass.....also check the plugs, they tend to crap out and run on one cyl or somthin like that
    1985 Tri-Z-
    Jul 2004
    minnesota
    689
    yes it has new plugs and i have tried riding it after him and its a rocket with me on it but with him its just got no balls at all, and it is running on both cylinders for sure,so i have ruled out the following so far, bad plugs, bad clutches, bad belts, bad plug wires, bad coils, bad track, bad slides, bad track wheels, but one thing i know are worn out is the wear rods, but again its a rocket with me, also it will have a new air filter pritty soon, and i have cleaned out the carb before i sold it. so what i am thinking is that it just cant power him around the greatesst.
    my trikes:
    1986 250sx
    Newfoundland
    5,280
    You did a great job of answering your own question. I fly on my little Bravo 250 but put a 250 pound man on it vs. 120 pounds of me and....
    Aug 2004
    Ab Canada
    4,368
    bravo, you did do a great job of figuring out the problem, ...plain and simple for you HIS ASS IS TO FAT FOR IT!
    1985 Tri-Z-
    Jul 2004
    minnesota
    689
    ok i sorta figured that was the problem all olong, but i thought there might have been something so tiny that would make a difference but there wasnt so anyway thanks for the help.
    my trikes:
    1986 250sx
