Results 1 to 4 of 4
Thread: Timing On A Honda 185s!
    Mar 2005
    SYRACUSE, NEW YORK
    HELP PLEASE!!! i need to know how to set the timing for a 1983 honda 185s!!!HELP PLEASE
    Jul 2004
    minnesota
    689
    first of all, make sure the piston is at top dead center, you can find this out by looking down the spark plug hole, and if it is at top dead center if you unscrew the cab by the pull start and look through it you should see a small "T", after that pull all the cdi stuff off, and aling the small dot on the cam gear with the "v" cut out in the top of the rocker box, then once that is done put the cdi stuff back on and make sure the base plate is straight and align the line on the piece that slided over the camshaft with the line on the base plate plastic thing and it should be correct and fire right up, this is how to set the timing.
    my trikes:
    1983 honda atc 200x-k&n filter
    2002 yamaha raptor 660r, yoshimura slip on, prm grab bars
    1978 chevy nova, 454 v8, bds blower, 150hp shot of nitrous, full roll cage, a real power house.
    1991 chevy s10 4x4 350v8.
    1986 250sx
    YES its fast NO you cant ride it.
    HaggLE is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jan 2005
    Newcastle, Australia
    330
    The bit about the CDI stuff is wrong. Do as you said but when lining up the black pickup with the rotor make sure that the "F" is visible in the flywheel hole not "T". "T" is used for the cam timing only not the ignition.
    Jul 2004
    minnesota
    689
    oops thats what i ment the "f" mark should be showing instead of the "t", my bad
    my trikes:
    1986 250sx
