Results 1 to 8 of 8
Thread: '83 250r with Honda 300cc Kit...
    Feb 2005
    Orchard Colorado
    659
    Question '83 250r with Honda 300cc Kit...
    I've got a Hondaline 300cc bigbore kit for my '83 250R. The cylinder is slightly scored and I need to get it rebuilt. I thought I remembered someone here saying they had talked to someone at Wisco and said they could make them if they have a minimum order of 10 pieces. I don't need 10, maybe 3 (for future use). Does anyone know what LA Sleve can do????
    What were you running for a pipe and carb on that 300r?
    1985 350x
    1985 350x
    1985 250r
    200 auto x
    1984 250r
    1982 250r
    85 Tecate
    86 Tri Z
    85 TRI Z
    98Wolverine
    99TRX 300
    Aug 2004
    Ab Canada
    4,368
    i belive you can also trim down a fl 350 piston to fit,,,, not sure tho how much the skirts need to be trimmed.....i know someone on this site knows!
    1985 Tri-Z-
    wales..uk
    1,318
    Hey BigBore
    check this ebay number out........4530580281..... is this what your looking for??....
    it's 3rd over but if you have sores on the bore then just get someone to bore it out to the right size...
    thanks
    Jun 2004
    potsdam ny
    1,227
    hey! someone should buy that and send it to wiseco and have the pistons made and sell THEM on ebay and on here...
    May 2002
    Dublin, Georgia
    635
    If you have around $4000 to place the minimum order of 24 from Wiseco, go for it. That is what stopped me from trying. Wiseco says 24 is minumum order. LA Sleeve will redo topend to use newer piston for around $500 - $600.
    84 ATC200X--Wife rode it once, now I can't get it back.
    84 ATC250R--Trying to find piston for 300R kit.
    85 ATC350X--Project finally under way, slow progress. For pics: http://groups.msn.com/ATCfriends/350xproject.msnw
    84 ATC200S--Freebie from a neighbor, needs topend rebuild and tires.
    Jun 2003
    South of Rochester, NY
    3,471
    Someone in another thread said there was someone in Seatlle area that had the 300R pistons available... can't remember what thread, but it was in the past couple weeks. Think it was one about 300R head gaskets.
    bruce
    '86 ATC350X - 'Go-Go Girl'
    '85 ATC70 - All Original
    '83 Suzuki ALT125 - Pieces
    Feb 2005
    Orchard Colorado
    659
    Thanks guys.
