New piston, valve job. Pipe, is stock, Uni filter, carb has stock jets. I will run with the choke in the middle position. I have oil to the head, so I'm thinking it is something in the carb. Set the carb per the clymers guide. With a Uni filter could the valve job be enough to need to jet up? I have the needle on the next to richest groove. It runs great for about 10 minutes then starts to ping really bad. The head was bugered up from this when I got it, hence the valve job and new piston. Any thoughts? I cleaned the carb once already, and have new o-rings on the intake. Help if I can get it running good I can sell it to someone without guilt.
