Thread: Calculating compression ratio
    Aug 2004
    Ab, canada
    1,222
    Alright, I need to know the formula for calculating compression ratio, I have bore, stroke, # of cylinders, displacement and clearance volume. What formula would I use from here to calculate the compression ratio?
    Rides:
    82 atc 200e
    83 atc 200e
    76 chevy k20 custom deluxe
    01 ford f250 diesel
    1938 Nash Lafayette
    1925 Nash Ajax
    My band:
    www.myspace.com/epicosgiliath
    Nov 2001
    B.C.
    933
    You'll need to know your combustion chamber volume too.
    Try this calculator.
    Join The Trike Registry Now!
    http://fly.to/TrikeHeaven
    Mar 2003
    Kansas
    1,507
    what calculator Mobular?
    Nov 2001
    B.C.
    933
    Aug 2004
    Ab, canada
    1,222
    Thanks!!!!!!!!!!!!
    Rides:
    82 atc 200e
    83 atc 200e
    01 ford f250 diesel
    1938 Nash Lafayette
    1925 Nash Ajax
    My band:
