Results 1 to 7 of 7
Thread: piston rings
    sideshow_bob's Avatar
    sideshow_bob is offline At The Back Of The Pack Arm chair racerFirst time rider
    Feb 2005
    New Zealand
    160
    piston rings
    hey guys
    yesterday as i was gassing it round my paddock(on my atc 200s) white smoke started comming out of the exhaust,now its not clouds and clouds of it but it is quite a bit,i am basing the problem down to piston rings,u guys rekon the rings are stuffed to?
    82 ATC 200...Getting torn down for resto/cleanup
    Looking for a "sport" trike in New Zealand..
    Jun 2004
    potsdam ny
    1,227
    it could also be if you put too much oil in it, but if you havent rebuilt the motor in a while, its undoubtedly the rings, i would put a new piston kit in it and bore it....just to freshen her up a little
    Feb 2005
    New Zealand
    160
    how much would that cost,as im in new zealand,and im a 14 yr old kid on low income
    Feb 2005
    New Zealand
    160
    and its got a perfect amount of oil,could it be a fowled spark plug or something?
    Jun 2004
    potsdam ny
    1,227
    well, if it still runs good, and your only 14.....id say ride it until it starts running crappy and by then you will have a job and you can put a new piston/rings in it....
    Aug 2004
    Ab Canada
    4,368
    what colour is your spark plug? ....dose it only burn white on start up when its cold or dose it do it when its warm too??
    1985 Tri-Z-
    Feb 2005
    New Zealand
    160
    ive got a job,but still paying my old man back for my other trike
    well i got a set of replacement rings,and a new gasket set,so ill put them on and give them a shot
