My second post on the forums.
Well having some trouble starting my 250 (81-82?). ive had it started revving it slowy to warm it up with choke on then it would cut out. then id do it with no choke and it wont start.
im giving it a bit of throttle and holding clutch in. but im not in gear. i am going to try tomorrow with choke on and bit of throttle then when it starts choke off.
its had new spark plug. and a fresh top end engine. it might need a new spark plug cap as it comes loose. but thats not the problem as i check its on tight.
i did have it started it earlier and rode it to test it. and it flew! its very fast! so i know it works.
also before i forget. its back fired twice the first time i left it for about half and hour. the second time i put it away till tomorrow as my leg is aching as i havent long recovered from a sprial fracture to my tibia and phibia. so its achy on my leg.
today is tomorrow and i got it out. and kicked it over and boom it started..... but then cut out. it only seems to start with choke down. and im trying to race to the choke to turn it on before it cuts out but it beats me!
Ive spent 2 hours outside trying and kicking it over. its started a few times and now it wont. when it started there was white greyish smoke coming out of the exhaust. i have put a little extra oil in with the gas as its not been broke in. so the first few rides im going to add a little extra. is this my problem maybe?
Im trying to get the tank off to inspect the spark plug! but the one nut is rounded off! DOH! so i have to find a pair of vice grips. it shouldnt be the spark plug as its a new one. a freind thinks its the spark plug connector. but its on tight.
Ive had a close inspection. and where the reeds are. in the casing is a crack. its not open just cracked and closed. maybe this?
Theres lots of reasons what it could be. but i know its not the fuel as the fuel is running. theres gas in the overflow. i tested the petcock and gas went everywhere so its not blocked.
also id like to say when kicking it over its like gas coming out of a gas gun. but out of the exhaust. really light white smoke. just puff puff puff everytime i kick it over.
the engine cannot be siezed the person said its had a new top end and its on its 2nd bore. with a wiseco .50 piston. new top and bottom gaskets. and like i said i had it running and took it for a spin!
i hope someone can help and give me step by step instructions on finding the problem!![]()
