Results 1 to 15 of 19
Thread: getting rust out of a tank
    Feb 2005
    long island, ny
    99
    Exclamation getting rust out of a tank
    i have an atc 90 that i just got from my friends back yard. im restoring it and inside the gas tank its all rusted, how do i get the rust out, and another problem i have is that in the back of the take there was some rust and there are 2 tiny lil holes that the rust made, what do i do without spending 100 bucks on a new tank
    Jan 2005
    Slatington PA
    4,372
    A product called Kreem works great! It is a white milky substance that coats the tank and it will never rust again! I have done 4 tanks so far with it. Has 3 steps and the 1st one is to pour in the rust neutralizer. Let it in 6,8,12 hours and usually the rust is gone! A bit more to the whole coating process then that but you get the general idea.
    It's about $30 at most cycle shops.
    http://motorcyclecity.com/Parts/tank-repair.htm
    Mar 2004
    Newnan, GA / Near Atlanta
    1,727
    I use muratic acid to eat the rust on the inside. Then wash it out good with water then acetone. It makes all the water evaporate instantly. THen I use a Product called Red Coat. I have used it on 2 tanks and it is much tougher and thicker than Kreeme used in kreeme kits. I and many other board members have used Kreeme and it eventually came loose. Mine did. Red Coat is much more forgiving and leaves a thick redish clear liner on the metal. It will even plug up holes pretty good. Even bigger sized ones. it runs $28 a qt. With a Qt you can usually do 2 tanks with a thick liner. It was originally designed for aircraft fuel tanks. Good Stuff.
    Clay Whitman
    Newnan, GA
    AMSOIL DEALER
    My Toys
    2008 Yamaha Rhino 700 SE
    Feb 2005
    long island, ny
    99
    yeah maby i will try that red coat stuff. where can i get that, will it fill lil holes cuz i got a couple holes in the rear of the tank caused by rust
    Jan 2005
    Slatington PA
    4,372
    Quote Originally Posted by ClayW
    Clay
    I had one problem with kreem one time as it was too thick (1 out of 4 tanks). Took way too long to flow around the tank. I should have known from past experiance to thin it out some which leads to my main ? With the red coat being thicker wouldn't you run into the same problem? Some tanks have a rim or collar up by the gas cap opening inside so the only way to drain is through the petcock hole. I would think thicker you'd have a heck of a time.
    Please explain how you drain the excess out or don't you have to with that product?
    Mar 2004
    1,727
    Actually what I do with the red coat is this. First off is just its about as thick as honey or something like that. Maybe just a hair thicker. The way I do it is this. Pour half a qt in and slosh it around real good coating the insides. I let the rest puddle in the bottom. Thats the bad area anyway for rust. After quite a few hrs i pick up the tank and slosh it around again and recoat the whole thing. Then let it set. Then again and again. Took 3 days last time. But it had a nice thick layer of that stuff in there. About the thickness of a credit card or drivers license. There is usually a small amount puddled up in the bottom seem, But thats good. Once it hardens its real tough. It kinda looks like that stuff you dip plier handles in to to coat them. Its very forgiving compared to kreem. You can thin it with MEK if you want. But I like it like it is. On my Bigreds tank that I used Kreem. I didnt have any excess to speak of.
    Clay Whitman
    Newnan, GA
    AMSOIL DEALER
    My Toys
    Feb 2005
    long island, ny
    99
    sweet that sounds cool, where can i get it whats the website, andwill it fil little holes that arein my tank
    Mar 2004
    1,727
    I fixed about 25 holes in a tank with it. one was quite big. Go to one of your parts stores, they should have it. The mom and pop smaller size stores especially. keep us posted . i dont know of a website that has it.
    Clay Whitman
    Newnan, GA
    AMSOIL DEALER
    My Toys
    Feb 2005
    Missouri, USA
    5
    what is a good cheap rust eating product that you could buy at a Lowes, Westlakes, or Walmart even? we have a spare tank for a 1986 200x that is in real nice condition that i want to put on my 200x because it has less dents.
    Mar 2004
    1,727
    Muratic acid. Cheap!
    Clay Whitman
    Newnan, GA
    AMSOIL DEALER
    My Toys
    Feb 2005
    long island, ny
    99
    hey say i get some acid and i get the rust out of my tank and i jb weld all the holes, should i still kreem it
    Feb 2005
    Missouri, USA
    5
    uh yes. muratic acid... okay good... we have a bunch of that laying in our garage. (for cleaning off bricks and mortar) .. thanks.
    Jun 2004
    Brazil, Indiana
    1,389
    where can u get that muratic acid at??? my hole 200x tank is rust..it has no holes in it but its completely rust on the inside..im not even jokin on that..u shine a light in there nad all u see is rust rust and more rust..i got it for a 185 cylinder and piston that i didnt need anymnore so i wasnt too worried about it..i thouhgt maybe the rocks and gas trick may do it but..no..lol..the gas turned red and its still treally really bad in there..will that muratic acid do the trick?? also..can i get hat kreeme or red coat or muratic acid at wal-mart or like an autozone place?? or would i have to go to a atv shop or somethin?
    trikes owned:
    85' 200m - sold
    84' 200x - sold
    83' 185s - sold
    82' 185s - sold
    85' 350x !!! - selling
    Nov 2004
    Belton, Kentucky
    70
    You can buy the muratic acid at Lowes or Home Depot or anyplace that sells concrete supplies. I bought my red coat at a tractor parts supplier.
    Jan 2005
    Slatington PA
    4,372
    Thats strange that you say to puddle is good? With the Kreem that's a big no-no. I have done 2 street bike tanks too, double coat and still had excess but your supposed to. You mentioned the kreem started flaking away I think? That could be because the surface wasn't properly cleaned and maybe there was residue yet of something on it? I had very good results with the Kreem myself except for the time it was too thick.
