Page 2 of 2 FirstFirst 1 2
Results 16 to 19 of 19
Thread: getting rust out of a tank
    Aug 2002
    Creswell, OR
    889
    Kreeme will work fine as long as you treat the whole area. Any rusting or non etched surface it will not stickk. If you have holes on the bottom inside, jb weld works fine to fill them. But if it is on the outside, then you need a better fix. Jb weld weakens over time anything that hits it, it will fall out. Underneath really never gets hit. To stop pooling on any of those products, you have to start in thin layers. I can do 4 gastanks with one Kreeme kit. I have never tried the red suff mentioned here. There is also a product out there called Por-15. I have not tried this but if I need to redo my gastanks, I will go this way next time. Anything that etches the metal, (muriatic acid or any other acid you use) should be treated. Honda tanks came treated originally. The acids use with these products takes that coating off. If you have very little rust, I recommend just a simple flush, with MEK, acetone and leaving it alone. Basically pulling articals out of gas tank. Gas does not cause rust, Water and air do.
    www.3wheeler.org
    * * * Nothing scares me more than someone who knows, with certainty, what is best for me * * *
    Aug 2004
    Ab Canada
    4,368
    do you dilute the muratic acid or just pour it stright in and fill the tank up to the top let it sit for 30 mins and dump it out??? and why would you have to coat it afterwards...aslong as the tank is full when you park it it shouldnt rust i would think
    1985 Tri-Z-
    Feb 2005
    long island, ny
    99
    yeah hes got a point if i clean the tank out with muriatic acid and then its just bare steel and the tank is full most of the time then i wouldnt have to worry about rust, and when i put the acid and i mix it 50/50 with h2o do i fill the entire tank up with the acid and water or just a lil and shake it around
    Jan 2005
    Slatington PA
    4,372
    Quote Originally Posted by My trike Sucks
    You don't have to coat it and can just keep it filled with gas but the second the gas gets low and air gets at it, those rusted parts that the acid neutralized will start to rust right away again.
    Totally up to you but I'd coat it & be done with it!
