Thread: 250sx gear oil
    bigb9582's Avatar
    bigb9582 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Feb 2005
    pa
    167
    250sx gear oil
    the gear oil in the rear of my 250sx is brown like mudd and very thick like molassis(sp?). is it sopossed to be that thick? when u touch it, it almost feels like u have elmers glue on trailprotrailpro finger. so im going to change it this weekend. 80w-90 gear oil is what i need right?
    Feb 2005
    Oregon
    772
    80w-90 is what my Dad uses in his SX.
    1986 310R
    1975 F150 4x4
    1975 F250 4x4
    1968 F100 2wd
    2001 Dodge 1500 4x4
    Nov 2004
    Belton, Kentucky
    70
    I use 80w-90 synthetic in my Big Red. Take it out for a ride and get the oil good and warm before you drain it. It will drain better when hot.
    Quote Originally Posted by bigb9582
    If your oil is contaminated then water is getting in there through a ripped driveshaft boot, bearing seals or where the diff bolts to the front of the swingarm. Better figure out where it's coming from or you'll lose that diff.
    bigb9582's Avatar
    Feb 2005
    pa
    167
    Quote Originally Posted by Dirtcrasher
    see i dont think it contaminated. because if stuff geting in means stuff should be coming out and there no leaks anyware. the oils full, its just thick.im thinking its just very old oil. its like working on a car that hasnt had it oil changed in years and the oil comes out like tar. plus the trike didnt seem like it was taken good care of. i mean it runs good and strong it just doesnt look to pretty from its broken plastic,dented gas tank,missing hand brakes, etc..
    after i change it ill keep a eye on the oil to make sure it not getting water in it. but im pretty sure its really old oil.
