Results 1 to 12 of 12
Thread: DG Krome Power, exhaust system.... ATC 350X
    86350X is offline At The Back Of The Pack Arm chair racerFirst time rider
    Does anyone run this exhaust? How loud is it, How is the power increase, what jets do you run with it? I am looking for an exhaust that has a little better tone than stock, but not too loud,,, for instance on my XR350 I run a cobra aluminum silencer, it is OK,,, My buddy runs an FMF power core on his DRZ400 and it is way too loud for some of the places I ride,,, So is the DG really loud or OK,,,,,, Thanks for any help
    2003 honda shadow 1100 spirit
    94 XR600R
    70 qa 50 with a 90cc motor in it
    87 XR80R
    82 XR500R
    1972 Honda z50A mini trail,,, Finally got a stock mini
    1981 CR450R
    2004 chevy silverado ls ext. cab 4x4 5.3L
    New Hampshire
    794
    The DG is nothing more then a cheap oem replacement. Theyre of shoddy construction, and far louder then stock. To make matters worse they hardly give you any power gains.
    They are cheap though. Cobra and DG are the same pipe.
    Not to argue, but I am very happy with the cobra on my XR350,, the fit and finish are excellent and I noticed quite a bit of midrange increase after rejetting,,,,,,,,, I was aware that cobra and DG are the same CO. I thought cobra was the cheaper alternative,,,,,, I do thank you for your input,,,,, So is the DG louder than the cobra? What exhaust would you recomend?????? My options are open, I was not aware of a better system, I posted to learn more, so please, the more info the better........ Thanks
    94 XR600R
    87 XR80R
    82 XR500R
    1981 CR450R
    -Literally- anything is better than a CObra or DG unless its one of the TUnable DG's. Youre better off with stock. FInd yourself a SUperTrapp maybe.
    May 2002
    Southeastern Wisconsin
    3,658
    Your never better off with stock unless restoring. DG and Cobra are cheap in everyway but they work and they will do just fine for a little more power. I'm not sure you have many more choices for the 350X anyway.
    Exxactly,, I plan on having a back up stock exhaust for when I restore it,,, but is there anything better than DG ( the krome power system looks real nice) for aftermarket 350X,,,,, I personelly don't like supertrap, I have it on my XR600 and Interceptor,,,, It's OK, but I like the cobra better,,,, supertrapp gets carbon all over everything around it and its just as loud unless I take all the discs out thenI lose power.......
    94 XR600R
    87 XR80R
    82 XR500R
    1981 CR450R
    New Hampshire
    794
    True, the dg pipes do boost midrange somewhat.
    I would probably retrofit a newer 400ex style silencer on and make a custom pipe/header or go with stock. There are plenty of options open to you, you just need to be a little creative.
    Thats an option I had not thought of,,,, I'll look into it does anyone have an atc pipe and a 300-400 ex pipe that you could compare and let me know how different they are?
    94 XR600R
    87 XR80R
    82 XR500R
    1981 CR450R
    Aug 2002
    332
    First of all, you're doing the right thing asking around. It's free, and advice can be worth a million dollars if you heed the right words.
    I run the DG Krome Power kit. You can view my website in my signature for installation and after pics, as well as some general pics of my trike with it installed. The kit fit well, was priced good, had provisions for either an '85 or '86 mounting (they are a tad bit different around the grab bar) and looks nice.
    It is louder than stock, probably as loud as any sane person would want to go, but it really makes my X sound tough without being annoying.
    I would caution you to make sure you get jetting done at the same time as the pipe is put on if you go with a chrome plated exhaust, because if the pipes get too hot from leanness, the chrome will burn blue like so many old hot-rods you see around. Thie blue is very hard to remove, if possible at all.
    For the money, it was worth it.
    Joel Morris
    Purdue University Graduate Student
    Mechanical Engineering Technology
    1985 ATC70
    web.ics.purdue.edu/~jsmorris
    als250 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    I can attest to Joel's trike. (Hey, Joel) It sounds sweeeeet !! Low, gutteral sound , but not too loud !
    Al
    p.s.(Joel,keep us updated on that soon-to-be Bad-trailprotrailprotrailprotrailprotrailpro X !!) 8)
    TF03/HASPIN ACRES /BADLANDS SURVIVOR!!! -LIFE IS GOOD!!
    '86 350x (latest addition)
    '85 250sx-200x frt.end,350x bars,plastic tank,3"hub spacers,22x11x10 Fast-Trekkers/.190 Douglas Red Label alum. rims/PRM desert grab bar
    '85 250sx(supertrap exhaust,chrome rims)
    '87 200x(restored)-'85 200x-'84 200x
    Nov 2001
    B.C.
    933
    A really simple mod:
    Add a Supertrapp disc kit to the DG megaphone. It quiets the roar a bit.
    Join The Trike Registry Now!
    http://fly.to/TrikeHeaven
    Thank you all for your input,,, I'll let you know what I get, and the results
    94 XR600R
    87 XR80R
    82 XR500R
    1981 CR450R
