there are several carb adjustments you can make to richen it up. first look at the needle and clip, it is easly loacated if you take the top of the carb off. then move the clip down on the needle,thus raising the needle up allowing more fuel to pass by. if that doesn't do it then you will have to get a larger main jet.
good luck,
85200xer
85 200x, powroll 12:1 comp , race cam, barnett clutch,supertrapp exhaust, 350x suspension.
01 800 summit, 159x2 track, dual pipes, reeds ready for snow.
www.geocities.com/bjh200x/PHAT_TRIKES.html
:Beerchug
