Results 1 to 7 of 7
Thread: Honda ATC 70 Seat Question
    Mar 2005
    Pittsburgh
    6
    Hi everyone!
    Just joined the forum, and I'm hoping to get some help.
    Where does the metal bracket in the picture mount? Does it go on top of the plastic in between the plastic and the seat pan? Or does it go under the plastic in between the plastic and the seat mounting bracket?
    Thanks for your help!!!
    Dale
    ATCnut is offline Got The Holeshot Arm chair racerJust too addicted
    Nov 2002
    Auburn Washington
    799
    Based on my parts list, it goes underneith the plastic. In other words, the plastic is between the bracket and the seat.
    ATCnut
    82 185s - sold
    83 200x (hopped up)
    84 200x (stock)
    84 70 (lost this one to the DMV)
    85 70 (soon to have lights, a foot brake, and CDI ignition)
    84 200es (parts trike) - sold
    85 350X (the best)
    85 350X (siezed motor, dream of a poweroll kit someday)
    85 250sx (frame was trash, got parted out)
    86 250sx (the tractor)
    86 250sx (a nicer tractor)
    86 250sx (an even nicer tractor)
    87 200x (parts trike, its really rough, a dog was chewing on it for a while)
    87 250es Big Red (the tank!!)
    Mar 2005
    Pittsburgh
    6
    Quote Originally Posted by ATCnut
    Bike Bandit has a schematic that shows it under the plastic also, but it just doesn't seem to belong there.
    Hopefully, someone that has one or has restored one will chime in.
    Thanks!!!
    Nov 2002
    Auburn Washington
    799
    I just went out in the gurage and looked at my 84 70. I went back and looked at my parts book. I think the schematics are screwed up. The page with the seat also has the part that goes under the fender, between the fender and the frame. The page with the fender has that plate. Without taking my fender and seat competly apart, I now think the plate goes on top of the fender, between the seat and the plastic, and the bigger part that goes between the fender and the frame goes on the bottom.
    ATCnut
    82 185s - sold
    83 200x (hopped up)
    84 200x (stock)
    85 350X (the best)
    Im pretty sure mines on top of the plastic,if u tighten the bolts down on the bare plastic it could maybe crack it.
    1983 Honda 110
    1967 Mustang
    Mar 2005
    Pittsburgh
    6
    It just doesn't seem right on the top or the bottom.
    Anyone else with a 70 able to take a look at how this plate is installed?
    Thanks!!
    Aug 2002
    Creswell, OR
    889
    It goes, seat, bracket, fenders. So it is inbetween the seat and fenders. You dont have that side picted but there should be 4 bolts? These actually hold the fenders down onto frame. Basically insert this into four holes you see on the pict you posted, then install your seat. You should have a second bracket doing almost same thing, only it is towards front. And it actually goes under fenders after seat is installed. The seat itsself will have bolts to attach this guy, after his bolts are fed through plastic hole. There are washers, use them, they save the plastic from over torquing. Locknuts are recommended if it doesnt already have them. Once seat is installed it all goes on frame.
    P>S sorry serious blonde moment, just relooked at pict but it is back fender four holes not front. :o
    www.3wheeler.org
    * * * Nothing scares me more than someone who knows, with certainty, what is best for me * * *
