Results 1 to 13 of 13
Thread: Need help finding beelder
    Feb 2005
    colorado
    103
    I cant seem to find the bleeder on my front brake system. Can you guys help me. Pics if anyone has any but if not that is okay to.
    Nov 2004
    Atlanta TX 3-states area
    1,592
    What kinf of machine is it?
    1985 Honda ATC 350X
    2003 Yamaha Banshee
    2003 Polaris Sportsman 500
    There are 3 kinds of people in this world, Those who make things happen, those who watch things happen and those who wonder what the hell happend.
    Feb 2005
    colorado
    103
    honda 200x
    Pa.'s Highest City
    8,058
    It is down on the caliper
    250RNUT is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Feb 2005
    CORTLAND NY
    379
    If your 8mm wrench fits on it, thats the bleeder.
    86 250R
    2-85 250R'S
    Feb 2005
    colorado
    103
    I know that, its just when I was trying to bleed the brakes I did not know what to open/pull on to bleed it. Is is the little ruber thing that you can pull on?
    Feb 2005
    colorado
    103
    Do I have to unsrew it. How far do i have to losen up the nut?
    Aug 2004
    Peoria, AZ
    625
    Quote Originally Posted by pomona51
    Make sure plenty of fluid in master resie (add more as needed, never leting it go dry). Take the rubber cap off, & put something below the bleed nut to catch fluid (I just use a rag then throw it out) then do this...
    1) Pull brake lever in & hold, losten nut 1/4 to 1/2 turn, listen for air bubbl'n out.
    2) Tighten nut, release brake lever.
    3) "Rinse & Repeat"...
    I just did my rear brake & it took like 20 repititions of the above, filling the master a few times, to purge most of the air!?!?
    Jan 2005
    Great Bend
    704
    if ya want something that will make bleeding brakes a whole lot easier, go to http://www.jlatvproducts.com/index.htm, look for a brake bleeder. I have one and it take less than 5 minutes to bleed a system that has no fluid in it. all you do is hook up the bleeder to the caliper and push the fluid through the caliper, hose and up into the master cylinder, and from there you tighten the bleeder screw and lightly pull on the brake lever and look for air bubblers if any show up. if there are no air bubles and the lever feels rock solid, you did it right and the process is over and you can re-install the master cylinder cap
    Feb 2005
    colorado
    103
    I figured that part out. Now that this is done. The part/piston that pushes the btake pads together is fully extended and now wont retract I dont know how to make it retract. Any help. Thanks.
    Jan 2005
    Great Bend
    704
    did you bleed the brake with the caliper off of the disc?
    ATCnut is offline Got The Holeshot Arm chair racerJust too addicted
    Nov 2002
    Auburn Washington
    799
    Use a C clamp to push the piston back in. Take the cap off of the resivour, and be ready to bail out extra fluid.
    ATCnut
    82 185s - sold
    83 200x (hopped up)
    84 200x (stock)
    84 70 (lost this one to the DMV)
    85 70 (soon to have lights, a foot brake, and CDI ignition)
    84 200es (parts trike) - sold
    85 350X (the best)
    85 350X (siezed motor, dream of a poweroll kit someday)
    85 250sx (frame was trash, got parted out)
    86 250sx (the tractor)
    86 250sx (a nicer tractor)
    86 250sx (an even nicer tractor)
    87 200x (parts trike, its really rough, a dog was chewing on it for a while)
    87 250es Big Red (the tank!!)
    Feb 2005
    colorado
    103
    Thanks for all of the help. I think I have everything working and now just have to put to together.
