ive got a weisco 12.1 compression piston and it isnt hard to kick. i dont think its got all the compression it should have. how much compression should it have and how do i got about checking it? (im sure my dad has the tool, hes at work now)
1985 atc 110 for sale
new carb
old trike
1985 200x
12.1 piston
oil cooler kit
white bors cam
super trapp exhaust
uni clamp on air filter
350x front end
did you bore and hone the cylinder for the size piston you bought? .. I have a feeling you didnt.
I am pretty sure your not getting the full compressuion of that piston because you say you are running 87 octane with no dentenation .. and I have a 10.25:1 and running 91-93 octane and Think I can still hear dentenation.
'84 Honda 200x
slow restro
ya i honned it and it was a stock size piston just high comp.
new carb
old trike
1985 200x
12.1 piston
oil cooler kit
white bors cam
super trapp exhaust
350x front end
did you measure the bore with a mike ?.. you realized that the clearence between the piston and cylinder was suppose to be .002 or .003 of an inch .. which is precision .. atleast I feel it is ...Originally Posted by vartiak15
my cylinder was like .004" out of round and burned oil like a mofo.
'84 Honda 200x
slow restro
I have like 170 psi with a wiseco 10.25:1. At least that is what is was a while ago. I have a compression guage that is on a hose and threads into the spark plug hole. The guages that you have to press into the hole kinda suck. You need some one else to hold it while you kick it.
Sam from Florida
1985 BIGRED $ 200X
