Originally Posted by
max
you cant weld it cause it has magnesium in it. i put some jb weld on mine. that stuff worked wonders. i got the jb stick. make sure your in room temp. apply the stuff on and let it cure for a few hours. the just sand it to where you want it the paint it. try this out before your go spending 1000 dollars to fix this. the jb is only about 5 dollars. good luck budy
max
uhhhh, im 100% sure there is no magnesium in the R's cases, even if it did you can go to a professional welding place and they can do it, it just has to be welded in a vaccuum chamber... i would never J
B cases, it is the most horrific thing you can do, and i doubt if there is any internal damage....just bring it to a welding shop have it TIG'ed and be done with it, no problem....
