Results 1 to 8 of 8
Thread: PVL ignition system for 250R's
    Jun 2004
    potsdam ny
    1,227
    anyone used a PVL system on their R? i am looking into getting one and was looking for an opinion on their performance....thanks
    Jun 2004
    potsdam ny
    1,227
    wow, nobody used a PVL before?
    Aug 2002
    New York
    1,098
    I have a PVL on my R. A couple friends do also. I bought it because I briefly ran my R on alcohol and needed the extra spark to make my motor run well. It works OK, but I would simply get a Ricky Stator rewind job for higher output if I had to do it again. Don't get me wrong, I've used a PVL for 6 or 7 years and it's fine, but you lose two things:
    First is your lighting. I really don't care about it, but it would have been nice to have lights for some night riding.
    Second, you lose your torque. It eliminates the flywheel and replaces it with a much smaller and lighter weight. I find myself having to downshift on the track more than I'd like. On a large sweeping turn, the motor screams, but I end up feathering the clutch out of many turns because I have no torque.
    Oh you also have to set your timing yourself with a dial indicator. Not a bolt on solution.
    Other than that, It works fine, but not enough to make me want to buy another one.
    Just my 2 cents.
    Jun 2003
    englishtown NJ
    2,676
    I have a cr ignition on mine and definety a loss of torque, but the revs are worth the small loss in torque, the pvl has almsot no flywheel, the cr has a flywheel about half the size of the trx.
    Aug 2002
    New York
    1,098
    This is what the PVL looks like
    Curtis-Tecate3's Avatar
    Curtis-Tecate3 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    352
    I have a moto-plat ignition on my 86 Tecate as this is the way it was when purchased used. The Moto-Plat is the predecessor to the PVL by the way. Setting the timing is a pain for sure. I have spoken to nearly all of the old factory tuners from the 80's and every single one recommended going back to the factory style ignition (At least on the Tecate).
    Curtis.
    I love anything with an engine except a lawnmower...
    1986 Tecate and original owner of a 1985 200X.
    3 wheeling since 1975.
    May 2002
    Texas
    2,670
    Here's an old article about those type of ignitions.
    http://www.3wheelerworldforums.com/s...747#post202747
    1986 Tecate
    1984 Tecate
    1985 Tri-Z
    1986 ATC350X
    1985 ATC250R (2)
    1985 ATC125M (2)
    1982 ATC70 - Original Owner
    175 TriMoto Frame with Pro-Tec Rear Suspension
    3-Wheelin' since '82
    bushwacker51 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jun 2003
    Cherokee, Oklahoma
    267
    I just put a pvl ignition on my 350 power valve motor. I have not had a chane to test it yet so dont know what kind of difference it will make. I am going to L.S. sand dunes in Waynoka, Okalahoma this weekend. I will let you know how it performs. It appears to rev up much faster then before. Glenn Oister
