Yes, you will probably have to flip-flop the positive and negative cable's on the inside of the welder around. On the one I used to use the lining that the metal wire slid through had to be switched for a lining that would allow the bigger diameter aluminum wire to slide through. This might not be the case with you though. That thing look's a lot more high tech then the one I used to weld with. And aluminum is supposed to be super clean before you weld it. Just my .02 cent's.
1985 Honda ATC 250 Big Red
"Ugly Betty" from the handlebars back it's a
1982 Honda ATC200es, from the handlebars
forward it's a 1988 Honda TRX 300 Fourtrax.
"If you wanna play, you gotta pay..."
