Page 1 of 8 1 2 3 ... LastLast
Results 1 to 15 of 109
Thread: atc200s implanted into a mid sized super bike (X2).......
    Mar 2005
    TEXAS-corpus christi
    85
    atc200s implanted into a mid sized super bike (X2)..QUESTIONS --- NEED HELP ASAP.....
    ok i know that this being 2 wheels in all doesnt pertain to this forum but thats where the motor lies - im about 95% done with my project and need some ppl who could probally give me some insight to a few questions so pls if you could help me id be very greatfull......................................... .........................................
    .................................... HONDA ATC200S ENGINE........................................
    1. need to know how this carb functions-- should i use a petcock or use the lines thatll go in through the side-of-the-top of the tank--- where the 2 lines would go in with a filter (air&gas) but if this would work where would the air line go to on the carb ......... whats a tube air vent & a over flow and where do they go too from the carb?
    2. my wiring, does this look correct? (pls refer to the diagrams as needed) if not what corrections do i need to make....the wires that are in the diagram that im useing for the project shows the only wires that the motor has coming out of it and the diagram that the manuals says for it says more -- that also confuses me ............
    3. what would be the best type of oil to use for this motor? could i just use castrol fully synthetic? also where do i drain the oil at? and whats the opening tube thats by the dip stick?
    ive been searching for these ansers cuase im so close too getting this thing running..................sorry for it not being full trike questions - but atleast i chose a atc motor
    Attached Thumbnails Attached Thumbnails 8c_1.jpg   ATC200Sx85.jpg   P1010005.JPG   wire diagram.jpg   f8_1.jpg   x2 wire diagram.jpg
    Jul 2004
    Mud hill. close to water !
    3,658
    Carb: The gas is gravity fed, so from the petcok ot the carb via fuel line.
    The air comes direct from uhm... well the air filter !!!! and boot.
    the overflow lines just hang down.
    The oil drain plug should be on the side of the tranny.. big 24 mm nut.
    Currently :
    Jun 2004
    Brazil, Indiana
    1,389
    uhm i wouldnt use synthetic oil unless its for "wet clutches" and make sure it clearly states that or your clutch will slip alot and it can cause other engine damage...just go to an atv shop and get some $7 a quart bel-ray thumper...its good stuff for these engines
    trikes owned:
    85' 200m - sold
    84' 200x - sold
    83' 185s - sold
    82' 185s - sold
    85' 350x !!! - selling
    Mar 2005
    85
    cool.......
    ill have pics up by tomorrow and probally have it running by friday .........Pete
    Mar 2005
    85
    ok heres the pics.......
    i call it the HONDA NOUSAGI X-192...............
    i still need to know what the tube is coming out of the motor that is located at the center behind the head - its open do i need to top it off? i went ahead and went with repsol 10w 40 4t moto oil ........... and my wiring i still aint got any feed back on that either is their suppose to be a pick-up coil cuase i was told it was coming from the cdi in this motor.............enjoy and if anyone out their has some answers pls feel free to reply..................Pete
    Attached Thumbnails Attached Thumbnails P1010169.JPG   P1010176.JPG   P1010172.JPG   P1010177.JPG   P1010179.JPG
    Nov 2002
    Kirkville, NY
    3,831
    Quote Originally Posted by NOUSAGI
    That is the crank breather, you should leave it open but make sure nothing can get in (especially water!)
    2004 BMW R1150R
    1972 Honda CT 70
    2007 Lifan 110
    Nov 2002
    Kirkville, NY
    3,831
    There are 4 main parts for the ignition system
    -the source coil (or know as the stator coil),
    -the CDI unit (the black box thing),
    -the CDI advancer (the part on the engine),
    -the ignition coil (has the spark plug lead on it).
    It would probably be easiest to use a 200s wiring harness and cut it down to fit the bike or at least base the homemade one off of it. The cdi unit has a 6 pin connector.
    2004 BMW R1150R
    1972 Honda CT 70
    2007 Lifan 110
    Mar 2005
    85
    Cool lets see..............
    could i go ahead and put a breather filter on it so i could make sure no water goes in their-----------ok lets get this correct on the carb - theres three outlets on it 1- where the gas flows in 2- the tube,air vent 3- the tube over flow
    1. ok, petcock to 1- gas flows
    2. 2-air vent to ? <<<<--------------where does this go again?
    3. 3-overflow to just a hanging down tube (opened)
    and that leaves the wiring ----- ill be working on that tomorrow thanks guys - -PETE
    Jul 2004
    3,658
    2 and 3 both hang down.
    the bottom line ( bottom of the carb bowl ) is used to drain the bowl. the top one is an overflow.. just hangs there.. zip tie it pointing down if you want.
    and 1... we got that figured out !!
    Currently :
    Houston,Texas
    1,044
    Thats cool as hell...it is going to do killer wheelies.
    "I am going out of this world.....the same way I came in...screaming and covered in blood."
    Nov 2002
    Kirkville, NY
    3,831
    Wiring help
    What do you have for your wiring now? The CDI advancer and the source coil are on the engine and I can seel the wires for them. I hope you have the ignition coil or there would be no place to plug in the spark plug. This leaves the CDI unit, do you have it? Here is a picture of an extra one I have.
    Here is the wiring diagram. I removed the wires for the lighting to simplify it.
    2004 BMW R1150R
    1972 Honda CT 70
    2007 Lifan 110
    Mar 2005
    85
    ok this is is what i have ..........
    wiring - from the side of the head which indicates is the cdi - 2 wires blue and green -------------------------from the altenator - black/red stripe, yellow, green------------------the ignition coil spark plug wire then off of that comes a black/yellow stripe ---------------- i dont have anything else where do i go from here? will be on like at 10 tonight central time thanks bigred
    Nov 2002
    Kirkville, NY
    3,831
    You still need the CDI unit (black box in pic. above), a kill switch (honda or a simple on-off switch), and some way of connecting everything. Personally I would get the honda 200s wiring harness and then shorten it if needed because the connector for the CDI unit is not a standard one so I don't know if you would be able to find it elsewhere and besides a used harness is not that much. Check the classifieds here and eBay for the harness, many people will include the CDI unit with it but if not PM me and I can hook you up with an extra one I have (sorry I don't have a harness though).
    You are going to have to post some pictures of you riding this thing when you are done, it is going to be fast! Is that the stock frame or did you make it?
    2004 BMW R1150R
    1972 Honda CT 70
    2007 Lifan 110
    Mar 2005
    85
    ok thanks fox
    Quote Originally Posted by thefox
    ok i have a complete wiring harness on ebay but i dout ill win it ..... well with the cdi unit - the black box is all i need left cuase i was gonna use a monastat a sort of relay to connect everything, if i dont win ill take you up on that offer but well have to get shipped fast
    Mar 2005
    85
    heres some more pics guys oh ya one more thing.........
    i found out that theirs spark coming from the black w/red stripe wire --coming out of the alternator ......................
    Attached Thumbnails Attached Thumbnails P1010171.JPG   P1010173.JPG   P1010174.JPG   P1010175.JPG   P1010178.JPG   P1010180.JPG
