Results 1 to 10 of 10
Thread: "o"ring or non-"o"ring??
    faf_racing's Avatar
    faf_racing is offline At The Back Of The Pack Arm chair racerFirst time rider
    Jan 2005
    pensacola florida
    187
    Unhappy "o"ring or non-"o"ring??
    whats the differance or which is better for an 84 r?? and why cant u adjust a chain on an 84r??? im lost
    Jun 2003
    South of Rochester, NY
    3,471
    You are able to adjust the chain on a 84R. I think you adjust it by sliding back the swingarm bolt like my 82R and 83-85 200X or possibly the 83-84R might have the adjustable axle carrier. I know the 85-86R and the 350X have the axle carrier adjustment, not sure when the R got that treatment in 2nd or 3rd generation.
    I actually use the "X-Ring" chain on my trikes. Pay about 2X the cost of a cheapo, but has a 34X wear rating, and have yet to wear one out!
    '86 ATC350X - 'Go-Go Girl'
    '85 ATC70 - All Original
    '83 Suzuki ALT125 - Pieces
    faf_racing's Avatar
    Jan 2005
    pensacola florida
    187
    hey thanx for the come back, ill go look at it cuz i wasnt sure and do ya know where i can get the "x' ring chain? if i cant get it adjusted,maybe it would be time for a rear sprocket too?
    Phoenix, AZ.
    6,719
    www.rockymountainatv.com has great prices on D.I.D. x and o rings.
    Dec 2003
    SE PA
    683
    O-ring chain is a much tougher chain. The rollers have grease inside them and they are sealed up with o-rings. The non o-ring chain is cheaper, and is used by motocross racers becaue it is lighter and easier for the motor to turn than an o-ring. They wear out quickly though. I recommend running the o-ring, or like Bruce said, the X-ring chain. They take abuse and last a long time.
    Feb 2005
    Oregon
    772
    You might want to get a little bit longer chain when you buy one, I found out my Tecate didnt have a stock swingarm so I bought two chains, I am now running a DID X-ring chain, I compared to to a non-x/o-ring chain and it looks massive, the chain itself is thicker and it is able to handle 8000lbs+ of tension forces, this can be good or bad. Forget about replacing an X-ring, it will last a couple years, but be sure you have a good quality sprocket, otherwise it will eat sprockets alive, I would reccomend staying away from allmnium sprockets also, I have had a bad experince with one, it was totally ruined after one ride. I was pretty mad. Hope this helps.
    1986 310R
    1975 F150 4x4
    1975 F250 4x4
    1968 F100 2wd
    2001 Dodge 1500 4x4
    wanta86r's Avatar
    wanta86r is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Nov 2004
    mn
    385
    I am experimenting with a new set of sidewinder chain and sprockets. The cost was more than i wanted to spend, but from what ive heard about their stuff, it will probably last forever. im using them on my 86R project. And i went with an o ring chain. Remember if you replace one sprocket, you should probably do both , and get a chain while your at it, especially if its old, alot of bad things can happen when chains and or sprockets fail.
    Poplar, WI
    531
    faf_racing: i have run both the o-ring and non-oring on my 83 R. The o ring is way better IMO..it lasts longer i have found and sounds cooler
    1983 250R ~ 1984 125M ~ 1990 POWER WHEELS!! trike
    Jun 2003
    3,471
    Quote Originally Posted by trikezilla
    Bailey, CO
    67
    84R Chain Adjustment
    You can adjust the chain on the 84r by turning the axle carrier.
