Results 1 to 2 of 2
Thread: 200x rim and tire
    Feb 2005
    colorado
    103
    200x rim and tire
    Does it matter which way our hub bolts on to your rim. Should the valve stem be by the rotor, brakes, etc... If your are sitting on the bike it would be your right side. Or should it be on the other side (left).
    Jun 2003
    South of Rochester, NY
    3,471
    Normally you put the valve stem opposite of the brake. Gives you more room to add air if you need to.
    Bruce
    '86 ATC350X - 'Go-Go Girl'
    '85 ATC70 - All Original
    '83 Suzuki ALT125 - Pieces
