Results 1 to 8 of 8
Thread: 38mm Airstiker Carb
    CUYAHOGA FALLS, OHIO
    1,242
    38mm Airstiker Carb
    Anybody Have This Carb On There 250r. If So, What Size Jets Are Yall Using And Where Are You Positioning Your Clips. I Just Got Mine. I Have A 295 Big Bore Motor, And A Complete Fmf, K&n. Any Suggestions On Jet Sizes. It Came With A 170
    Thanks Max
    3-85 ATC 70
    86 ATC 250R
    86 WETBIKE
    01 KX250
    2011 KAW SXR800- 35YR EDITION
    05 HERITAGE/SPRINGER/SOFTTAIL
    Mar 2004
    Eastvale, CA
    630
    Good choice on carbs! Mine is jetted for my 310cc R with a 175 main and the clip in the middle position. I don't recall what size pilot or needle I'm running but it is whatever came with the carb and works fine.
    It sounds like yours is set up for a good starting point, but may need some tweaking based on your riding conitions, elevation, temperature, etc. Do some plug chops/readings and go from there.
    Current Ride (Purchased new in Oct. 84) - 1985 Honda ATC 250R w/ ESR 310cc big bore kit
    Wife's Ride - 2009 Polaris RZR 800
    Kid's Rides - 2009 Yamaha Raptor 700, 2008 Yamaha Raptor 250
    Former Rides - 1975 Honda XR 75, 1979 Yamaha IT 175, 1978 Honda ATC 90, 1980 Honda ATC 110
    got sand?
    Phoenix, AZ.
    6,719
    I have the non-air stryker version. Running a 175 main, 50 pilot, middle clip. Mods are FMF fatty, rad valve, uni clamp on, MX ported.
    Dec 2003
    SE PA
    683
    What is the difference between the air stryker and the non?
    3leggeddog's Avatar
    Nov 2004
    max don't buy jets!!!!!!!!!!!!!
    i got ya,i got everytinhg from a 170 to a 190.you may need a 55 pilot though.it should have a 50 stock.r you gonna run a lid on the air bx?
    Jun 2004
    potsdam ny
    1,227
    the airstryker has four float bowl vents instead of 2....this allows the fuel to flow more freely into and out of the float bowl with little to no vaccuum....also, if you need jetting help, call up sudco or ESR and give them your motor mods and they will tell you what you need for jetting and needle clip settings and/or which needle you need...
    nate b is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Central WI
    433
    I would start off with a 175 and work my way down doing plug chops.
    I run 170-172 in summer 175 in cooler weather and a 184 in the winter.
    85 atc 250r;
    PSI porting & head mods
    fmf pipe & silencer
    boysen rad valve & reeds
    38mm air stryker
    1,242
    thanks
    i appreciate your inputs ever so much. i sounds like i might have gotten lucky cause the carb has all the settings you guys are talking about. we will see. ill let ya know.
    max
    3-85 ATC 70
    86 ATC 250R
    86 WETBIKE
    01 KX250
