I need to change my forks seals...
can anyone tell me what parts I need
and what the factory settings are for the 86 Z (this will be different than the 85)
Oil wt?
Amount?
Thanks!!
Oil wt?
Amount?
Thanks!!
SEND ME PM HERE - CLICK HERE
Dirtbikes:
1988 Yamaha DT
triztunes or chainsaw should know, i know the 85 uses 15wt, 11.5oz.s per tube
Went to my office and found the 86 Tri Z manual:
For the 86 Z (remember the 85 has thinner forks and 1 inch less travel):
Recommended Oil- 10 wt or SEAQ # 10 fork oil
Oil Quantity- 418 cm 3 (14.7 Imp. oz, 13.09 US oz)
**Oil Level:
Std: 180 mm (7.09 inches)
MIN. 168 mm (6.61 inches)
MAX. 212 mm (8.35 inches)
** Front top of inner tube fully compressed without the springs.
Dirtbikes:
1988 Yamaha DT
remember, you can fine tune rebound a little using different weight fork oils...
