Results 1 to 4 of 4
Thread: Factory fork Oil Weight and Amount for 86 Z?
    May 2003
    Houston, Texas
    2,409
    I need to change my forks seals...
    can anyone tell me what parts I need
    and what the factory settings are for the 86 Z (this will be different than the 85)
    Oil wt?
    Amount?
    Thanks!!
    SEND ME PM HERE - CLICK HERE
    1986 ATC 250r, 1986 Tri Z, 1990 LT 500R "Quadzilla"
    Dirtbikes:
    1994 KTM 550 MXC (yes its a two stroke...66 hp stock!)
    1988 Yamaha DT
    Front royal, va
    2,186
    triztunes or chainsaw should know, i know the 85 uses 15wt, 11.5oz.s per tube
    May 2003
    Houston, Texas
    2,409
    Went to my office and found the 86 Tri Z manual:
    For the 86 Z (remember the 85 has thinner forks and 1 inch less travel):
    Recommended Oil- 10 wt or SEAQ # 10 fork oil
    Oil Quantity- 418 cm 3 (14.7 Imp. oz, 13.09 US oz)
    **Oil Level:
    Std: 180 mm (7.09 inches)
    MIN. 168 mm (6.61 inches)
    MAX. 212 mm (8.35 inches)
    ** Front top of inner tube fully compressed without the springs.
    Dirtbikes:
    1988 Yamaha DT
    Jun 2004
    potsdam ny
    1,227
    remember, you can fine tune rebound a little using different weight fork oils...
