Results 46 to 48 of 48
Thread: How to beat a tri-zs powerband
  1. #46
    Feb 2005
    Oregon
    772
    Quote Originally Posted by BLAZERONE22
    When you mix your oil and gas, only use a 1/4 of the amount of oil that you normally use, with less lubrication this will slow your piston down and help keep that frontend down.
    I know a lot of people who have tried that one, it worked too!!!!
    1986 310R
    1975 F150 4x4
    1975 F250 4x4
    1968 F100 2wd
    2001 Dodge 1500 4x4
  2. #47
    Watertown, New York 13601
    3,382
    If you don't like the powerband you have now Walgreen has a sale on new ones.
    1985 YAMAHA TRI-Z 250 sold
    2006 YFZ 450
  3. #48
    Rittman, Ohio
    6,276
    Quote Originally Posted by jinxy
    how do you beat a tri zs powerband wen it kicks in?
    almost threw me of! i went thru 1st then hit 2nd & i felt lite as a feather + jingly - it felt like the front end come up... wich it probaly did
    ive been told to put my head forward & lean a bit 2 the front
    Sometimes if you are riding in the UK, but you put in your 3WW profile that you are from Oregon, it fools the trike into thinking its actually in the Rocky Mountains at a much higher elevation than your ISP in the UK, and it runs leaner causing erratic acceleration.
