1. There is a cable that runs from the kick starter housing to the front of the head. I suspect it to be a Compression Release. What exactly is its function and how does it affect performance if disconnected?
2. On the left engine cover, there are 3 ports which appear to be some sort of crankcase ventilation. The 2 inner ports run to the rear of the trike, but not sure exactly where. The outer port is not connected, but the only thing I can locate nearby to cnnnect it to is the 1/2" crankcase hose that runs right under the frame (carb area) to the airbox. There is a vacuum "T" located in that hose. Does this outer port connect to that vacuum "T"?
Thanks
