turn it around and run it. if there are knocks that's bad. you probably have done some damage...time will tell. my neighbour did the same on his foreman and he had to rebuild the top end, so good luck!
1985 250sx.
1991 trx 200,1500 superwinch,snow plow(hers)
1985 125trx. kids toy
05 baha 90 mini quad
110 atc (just picked it up)
garmin map60c
I would suggest buying a manualy for 30 bucks or so. Its alot cheaper than a new motor. If you dont know what you are doing you should ask before you do it, not after.
today I went over after school and turned the filter around. We drove it around the yard for a bit and it sounds good. Filter went in a lot better too.
Thanks for all the help
