Ok I've finally tore into the top end of my 175 Tri-Moto. It looks like I don't need to bore it out. I tried to feel any scatches in the cylinder with my fingernail and it's pretty smooth. Looks like all it needs in a hone. The piston is the original(no number stamped on top) and looks pretty scratched up. Now should I go ahead and replace the piston, or just run the old one with new rings? I read somewhere that you should replace pistons anyways after so many hours. I'm about to make an order to Hyperparts and like to know if there is anything else I need before I order. Yes i know i need the gaskets.
Thanks in advance.
