so i was sitting around my dorm room today and i thought to myself that they should have something like a lowering link for the tri z's. i also thought it would be better to have it adjustable to an extent. so i put my engineering schooling to work and did some calculations and compared the stock link to the one i thought up. made sure the stresses would be within the limits of the metals. I drew up a quick cad drawing and CNC program. and i think im gonna CNC one up out of aluminum and steel. make it threaded so you could adjust it out from 1 inch drop to 5 inch drop. not sure how it will work out when i put it on my wheeler, but i got some free time now to mess around. i wrote up the mastercam CNC code only to find the schools machine shops CNC to be down till they can put a new keyway in the motor shaft. so as soon as its up im gonna mill it out. im gonna try and post the cad drawing. if there is no picture with this post could someone post it for me?
the gold colored piece is going to be threaded steel, kinda like a tie rod end, the grey piece will be either 6061 AL or Billet. the bolt holes will use the stock pressed in sleeves and would use the stock bushings. i will drill down the center of both pieces and install a grease zirk on the top so they will be able to be greased same as stock.
Now for what i am really after, does anyone have any ideas or things that worked well for them before. maybe a homemade link that would slicker then snot. What do you guys think of this design. any input will be greatly appreciated.
Hopefully if it works ill try and make up like 7or 8 if people want them. it all depends how they work/turn out.
now to try and post the picture...![]()
