Results 1 to 15 of 20
Thread: Engine Swap
    Engine Swap
    Has anyone put a 350X eng/trans on say a 250X 4-wheeler frame? 8)
    350Xrider is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jan 2002
    Huntington, W.V.
    320
    I have not done it before, however I know it is almost a direct bolt in. I think the only thing you have to do is notch the frame in one place to route the oil line correctly. I have the edition of ATV sport where they did this conversion. It is to the best of my knowledge one of the easiest conversions to perform.
    ATC350X,ATC70,1991 RM 250,XR500,TM400,TS400,Foreman400 4X4,Polaris 425 Magnum,ATC 90, 1982 175,1973 Honda Trail 90,1980 CR80,1981 CR80,
    theeechozen1 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Nov 2002
    368
    Freaksfix has one, maybe he would be so kind as to answer some of your questions
    1985 YAMI TRI-Z RZ350 POWERED
    1986 250R STOCK WITH FMF & K&N
    1986 TRX70 mini golf cart
    TRY AND CATCH ME.....................I HAVE MO CYLINDERS THAN YOU !!!!!
    Nov 2002
    Oregon
    65
    there is a mount on the rear of the motor that needs to be cut. you can get a exhaust from powroll. my friend did this swap. powroll has a kit but my friend did not use it. he just got the exhaust from them. http://www.powroll.com/honda_atc_350x.htm
    Detroit, MI
    837
    Freaksfix does not have a 250x with a 350 motor, he has a 350X converted to a 4 wheeler. I have herd of similar sawp, and the 350 motor into a 250r chassis of any sort i hear is easy as pie too.
    1986 ATC 250R(for sale), 1963 AceCraft boat w/40HP Evinrude, 1981 Arctic Cat El Tigre' 440 L/C, 1992 GMC Safari Van.
    Nov 2002
    368
    are the 250r and 250x frames the same??
    CENTRAL NY
    1,709
    No the R frames are bigger and stronger. The R frame looks to be the easyst..
    1985 250R Selveys port job and pipe
    1985 70 piped for lil'freaks
    2001 TRX90
    ATC 90+250R+BEER= Drag Bike
    1984 ATC70 Pit bike
    1984 110 for sale
    Nov 2002
    368
    I see your project has changed from a twin cylinder atc, to a four cylinder atc!! Are you trying to go one up on me!! J/K Are you going to use a crotchrocket motor of some kind, or are you thinkin more along the lines of a kz550, or honda cb motor?? Just curious
    May 2002
    Southeastern Wisconsin
    3,658
    The 350x motor to 250X/300EX frame is the easiest swap. The motors are very similar. There is more work involved when you try it with an R frame.
    Roanoke, VA
    4,038
    If you do the swap into a 250x chassis, you might want to consider a longer s-arm because it will constantly want to wheelie (I learned the hard way). My brothers friend has one and it is awesome :-P
    [20:55] <waterpumper> putting a racing pipe on a Foreman is like putting a high dollar bikini on a 400 pound chick...just because it fits doesn't mean it looks cool
    Nov 2002
    Oregon
    65
    the 350x shock and swingarm bolts on to the 250x. the shock is better , i don't know if the 350x swingarm is longer or not or if the axle is wider.
    CENTRAL NY
    1,709
    Quote Originally Posted by theeechozen1
    I got pissed at the sl350 motor, and figured no one was bitting on the CB550F i have for sale
    2001 TRX90
    1984 ATC70 Pit bike
    1984 110 for sale
    Belsano, PA
    1,387
    conversion
    here is mine. It is a 1998 300EX with a 86 350X engine. I swapped the engines in less than 7hrs. If I would have had an exhaust, it would have been ridden at the end of the 7hrs. i couln't see buying a $460 exhaust at the time. I wasn't sure if I wanted to keep the engine in there or not. I ( with the help of a friend with a exhaust shop, made a exhaust for it in about 3hrs, that following saturday. All the was needed to do the swap, is Exhaust, file down the Oil supply banjo bolt ( goes to the head ) 1/8-1/4 inch for clearance, and cut off a 1 1/4 from the upper rear engine mount boss and make 2 spacers 9 one for front bottom, and one for top rear) The engines are VERY similar, in fact, the side cases will bolt on each other. I also used the NEW clutch from the 300ex engine, and put it in the 350x. Here are some pics of this machine.
    Also check this link to see some more pics
    http://www.msnusers.com/Speedbump/shoebox.msnw
    250x conversion
    try this on for size. here is my 250x. guess what engine this is.
    Detroit, MI
    837
    If I remember right you told us it's a CB 750. Bet that thing flies, and is more stable than the 3 wheeler LOL!!
