Hi guys. It's been a loooooong time since I've been on the board here (and somehow I'm missing an 'r' on the end of my name now too...?).
Anyways, I have this '89 CR500 that I want to lower down a little so the seat is not so high. I've already adjusted the rear shock spring adjuster nuts almost as far up the shock body as they will go, there are only 4 threads left, and the spring is at full-length, according to the Chilton manual (11 inches at full drop). There is still pre-load on the spring, but I don't think there will be enough if I raise the adjuster nuts any more than they are, so I don't think I have any more adjustment there. I need to bring the bike down another inch or two.
Is it possible to use a shorter spring on the rear shock? I'm thinking a CR250 might have a shorter spring, since my friend's '88 CR250 has the same size tires as my bike but his bike sits lower than mine and his shock still has some adjustment left in it. The bikes seem almost identical in all respects, except height and obviously engine size, and alot of parts seem like they would interchange.
I also looked at possibly cutting down the existing spring, but it appears to have flattened ends on it and cutting it would eliminate those formed ends and the spring might not mount correctly in the shock.
Any ideas are welcome. Thanks.
