after two days of trying to pull the flywheel off of my 185S to inspect any eletrical components underneath the fly wheel it wouldnt work, we bent 6 bolts trying to pull it with a flywheel puller and it wouldnt come off, we gave up and put it back together and i went and cleaned up any electrical connections, it turns out that two wires that were plugged together werent meant to be. so after 2 days of work it turned out that i had to unplug two wires to get spark. after a quick carb and air filter clean its running and ready to ride tho there is holes in the exhuast. Will a 200S exhuast and carb bolt up to my 185? and if so will there be a performance gain?
pretty hard..not to hard tho and thenit should "pop" off of there and you can twist that bolt more..it took me a while to get mine off when i first had too
