Thread: Crank Seal and Tri Z...Questiion!!
    May 2003
    Houston, Texas
    2,409
    Can you change the oil side crank seal in a Tri Z without splitting the cases?
    How about the ignition side?
    Thanks
    SEND ME PM HERE - CLICK HERE
    Dirtbikes:
    1988 Yamaha DT
    Front royal, va
    2,186
    yep, doing mine wednesday night
    left side , pull flywheel, remove stator, pry out with a screwdriver
    lube the new one up real good, use a deep socket to drive home
    right side. remove clutch cover, clutch basket, remove crank/waterpump gear
    then there is a +screw with a metal holding thingy holding the seal in behind the clutch basket,
    once out pry out with a screwdriver the seals are like $8 each
    if you dont get it going PART IT OUT!!!
    May 2003
    Houston, Texas
    2,409
    Thanks Nathan...I did get the Z running. Probably alot of excess oil in the crank was making everything super rich.
    I suspect a bad oil side crank seal....and will change both sides. I'll probably take it to a shop.
    Dirtbikes:
    1988 Yamaha DT
    Watertown, New York 13601
    3,382
    Quote Originally Posted by 03 ORANGE SHEE
    If you don't get your's going you should part it out.
    1985 YAMAHA TRI-Z 250 sold
    2006 YFZ 450
    May 2003
    Houston, Texas
    2,409
    Nathan...ha ha!! I gotcha man....well we may see about that.
    Dirtbikes:
    1988 Yamaha DT
    May 2003
    Houston, Texas
    2,409
    Its going pretty damn good now. I will say that once this crank seal leak is fixed I have no doubt that my 86 Z (stock) is very very close if not equal to stock low hour 86 R in power....we will have to see when I get them side by side and can ride them back to back.
    A broad powerband (as found in the Z) can be deceiving!
    Dirtbikes:
    1988 Yamaha DT
