Results 1 to 15 of 16
Thread: check out this horsepower chart!!!
    Front royal, va
    2,186
    1. Suzuki Quadzilla LT500 ---------> 51srwhp / 390lbs = 0.1308 horsepower per pound
    2. Cannondale Cannibal -------------> 38srwhp / 375lbs = 0.1013 horsepower per pound
    3. Yamaha Banshee ------------------> 37srwhp / 386lbs = 0.0959 horsepower per pound
    4. Suzuki QuadRacer 250R --------> 31srwhp / 327lbs = 0.0948 horsepower per pound
    5. Kawasaki Tecate 4 ----------------> 33srwhp / 339lbs = 0.0944 horsepower per pound
    6. Honda 250R --------------------------> 31srwhp / 329lbs = 0.0942 horsepower per pound
    7. Yamaha Raptor 660R -------------> 35srwhp / 399lbs = 0.0877 horsepower per pound
    8. Suzuki Z400 / Kawasaki X400 -> 32srwhp / 370lbs = 0.0865 horsepower per pound
    9. Bombardier DS650 BAJA --------> 39srwhp / 475lbs = 0.0821 horsepower per pound
    10. Honda 400EX -----------------------> 29srwhp / 374lbs = 0.0775 horsepower per pound
    11. Polaris Sport 400 ------------------> 34srwhp / 481lbs = 0.0707 horsepower per pound
    12. Polaris Scrambler 500 2WD ---> 35srwhp / 523lbs = 0.0669 horsepower per pound
    13. Yamaha Blaster --------------------> 20srwhp / 320lbs = 0.0625 horsepower per pound
    14. Yamaha Warrior -------------------> 21srwhp / 397lbs = 0.0529 horsepower per pound
    15. Honda 300EX -----------------------> 17srwhp / 377lbs = 0.0451 horsepower per pound
    16. Kawasaki Mojave -----------------> 17srwhp / 379lbs = 0.0449 horsepower per pound
    17. Honda 250X -------------------------> 15srwhp / 351lbs = 0.0427 horsepower per pound
    18. Honda 250EX -----------------------> 13srwhp / 349lbs = 0.0372 horsepower per pound
    19. Suzuki QuadSport 230 ----------> 11srwhp / 309lbs = 0.0356 horsepower per pound
    20. Wal-Mart PowerWheels ---------> 0.5srwhp / 50lbs = 0.0100 horsepower per pound
    got this off another site, it was posted by troll /troll 2 ..ol' quadzilla on top, best power to weight ratio
    Phoenix, AZ.
    6,719
    A 250R weighs in at 291lbs. I assume they mean the TRX but I thought the TRX actually weighed more than 329. Edit: and HOJ states the hp at 39 but I don't know what srw stands for. Different measurement technique?
    Front royal, va
    2,186
    i noticed that too .has to be the trx , too bad they didnt do the atc 250r, as well as the tri-z and t-3, heck, it would be nice to have every one made on the chart
    Phoenix, AZ.
    6,719
    Do you know if that weight is right for a TRX? I'm impressed if that's all they weigh.
    And any idea on the descrepency between these hp numbers and Hondas?
    Front royal, va
    2,186
    i dont know, billy or tim sr. should know, some numbers are high, but alot are low, i have noticed they all are within 3-4 hp from what the factory states, but the r, i know the first year zilla (87) has 53-55hp, and the later years are 51-53 hp, the intake track is larger that year (87) ..hate to feel the rush of that powerwheels thingy!!!
    YAMAHA_Jim's Avatar
    YAMAHA_Jim is offline 4 Motos, 3 Wheels, 2 Classes, 1st Place Arm chair racerJust too addicted
    Apr 2003
    Rock Hill,NY
    1,000
    I'm wondering where the yfz450 stands against the others.
    May 2002
    Southeastern Wisconsin
    3,658
    Quote Originally Posted by YAMAHA_Jim
    http://www.fmfracing.com/dynocharts/..._powerbomb.gif
    http://www.mainjettech.com/yfz450.html
    http://www.gtthunder.com/dynoyzf450stock.html
    http://www.trinityracing.com/pages/d...fz450pipe.html
    IDK, from my experience I'd say it's not the first two.
    May 2002
    Dublin, Georgia
    635
    Those are probably rear wheel horse power numbers measured on a dyno where as Honda gave out the engine horsepower numbers.
    84 ATC200X--Wife rode it once, now I can't get it back.
    84 ATC250R--Trying to find piston for 300R kit.
    85 ATC350X--Project finally under way, slow progress. For pics: http://groups.msn.com/ATCfriends/350xproject.msnw
    84 ATC200S--Freebie from a neighbor, needs topend rebuild and tires.
    250RNUT is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Feb 2005
    CORTLAND NY
    379
    Man, I was hoping the ds650 was better than that.I am looking to buy one of those.
    86 250R
    2-85 250R'S
    Opelousas, Louisiana
    1,337
    350x with cobra has 23 at rear wheel and it weighs 320
    23/320=.071875
    1986 350X K&N filter, DG Krome Power exhaust
    1982 110 UNI filter, Cobra megaphone exhaust
    1982 honda 110 exhaust for sale, PM me.
    Phoenix, AZ.
    6,719
    If you use HOJ's specs the R is ahead of the 'zilla. If you use 31 hp instead it's in second place. Not sure the specs on the other water pumpers.
    39hp: 0.1340
    31hp: 0.1065
    Aug 2004
    Peoria, AZ
    625
    Me thinks... srw = Stock Rear Wheel.
    Yah I think the TRX's are almost that light, cause they sure dune like no other!
    Mar 2004
    Eastvale, CA
    630
    The hp listed in the chart is either for an 83/84 R or it's listed incorrectly. All stock
    85-89 water pumper R's have the same approximate 39hp whether they're an ATC or TRX (same motor).
    Current Ride (Purchased new in Oct. 84) - 1985 Honda ATC 250R w/ ESR 310cc big bore kit
    Wife's Ride - 2009 Polaris RZR 800
    Kid's Rides - 2009 Yamaha Raptor 700, 2008 Yamaha Raptor 250
    Former Rides - 1975 Honda XR 75, 1979 Yamaha IT 175, 1978 Honda ATC 90, 1980 Honda ATC 110
    got sand?
    Washingtons Crossing, Pa.
    2,977
    Thats been around forever .... alot of it isn't spot on correct. For example: the 350X only having 21hp - the factory manual states 28hp. Even if you were to take away shaft hp to rear wheel - you wouldn't loose that much unless the brake was on. Now as for the DS650 goes - Rotax claims 48hp on the motor, the chart only lists 39hp - to loose 9 horsepower from just a 90 direction change is just plain absurd - thats nearly a 20% power loss.
    Thats what SRWHP stands for ....... Stock, Rear Wheel Horsepower.
    Bill X_R is offline Bill "The Finger" XR oo|oo Arm chair racerJust too addicted
    Feb 2003
    Cincinnati, OH
    672
    GO CANNONDALE!!!!
    86' 250 R
    02' DS 650
    03' Cannibal
    03' Haspin Vet
    04' Haspin Vet
    05' Haspin Vet
