Results 1 to 12 of 12
Thread: 86 250r
    Mar 2005
    Nebraska
    118
    86 250r
    Well after looking for a little while for a faster rig to replace my so to be sold 86 200X, I found a 86 250R in the paper. It says ORIGINAL. So what are the trouble spots on these. I know it is water cooled and 2 stroke but that is pretty much it. Tell me what I should look for and what I should expect. Is this the quad beater I always dreamed of? or at least the raptor beater? The better question is, is this the rig I aways needed to ride with my wifes 400EX?
    Mar 2004
    Gettysburg PA
    498
    they are great trikes and realy fast it will be able to beat the 400ex and rapter pretty easily
    and with a little bit of aftermarket mods they can be made to destroy just about anything
    parts are still pretty easy to find also
    My Trikes
    1985 250sx
    1986 250r
    Parting out 85 kxt tecate pm me with your needs
    Anaheim
    1,270
    only thing * need to look for is piston slap, the rest the engine is pretty bullet proof the stock R's are very nice machines with little problems if any at all stock they take anything from th 400ex-banshees stock to stock, * add pipe jets and a k.n and watch it fly
    adam
    86 ATC 500R the duner..
    85 ATC 500R...the not quite finished faster duner
    1985 ATC 250R Bone stock!!
    1985 ATC250R mx/duner
    1986 TRX370R MX/Duner
    94 Banshee 400PV Cheetah 105RWHP
    Mar 2005
    Kansas
    26
    im not sure what they're called but they look like little slices of rubber right on the bottom carrier. I was told that the swingarm will start splitting right there.
    Mar 2005
    Nebraska
    118
    Thahks guys, you have done a good job in helping me out. Anyone else?
    Aug 2004
    East Central, Missouri
    546
    Thumbs up
    Take it from me.....you will love it.
    I've never looked back since getting mine.
    They're LIGHT, nimble and FAST!
    You know the "standard trike maintenance" routine when buying a used one I'm sure, right?
    Almost every trike I get tends to need these items so check them and figure them into your purchase price:
    1. Front wheel bearings (grab and wiggle back and forth....sometimes they're so bad you can shake the forks and it'll rock)
    2. Reseal/re-oil the forks (moisture around seals or if they're dry-squeaking)
    3. Some brake work (excessive handle travel, squeaking, rotor damage)
    4. Most of the time....rear axle bearings (grab the axle on both sides and yank).
    You made a great choice.
    Don't let the "Man, that thing is FAST!" thought scare you, either.
    They are FANTASTIC woods/trails trikes!!!!
    CUYAHOGA FALLS, OHIO
    1,242
    Crack Case
    Check For Case Cracks Around Chain Guard Area.
    Max
    3-85 ATC 70
    86 ATC 250R
    86 WETBIKE
    01 KX250
    2011 KAW SXR800- 35YR EDITION
    05 HERITAGE/SPRINGER/SOFTTAIL
    Aug 2004
    546
    Right on.
    If there are no cracks, make sure there's a case saver.
    If there isn't one? BUY ONE...they're CHEAP insurance.
    You don't want to be replacing a side cover....they're around $250-300 per side if memory serves me right.
    Opelousas, Louisiana
    1,337
    ditto on that case saver.
    it will kill a 400ex.
    1986 350X K&N filter, DG Krome Power exhaust
    1982 110 UNI filter, Cobra megaphone exhaust
    1982 honda 110 exhaust for sale, PM me.
    Aug 2004
    546
    You can't beat a good, solid R for "bang for the buck".
    I have MAYBE $1900 in mine and it'll keep up with if not outrun (depending on rider skill) a lot of sport quads that cost almost 3 times that much.
    It's always nice to walk away from a new bike with my dinosaur.
    Anaheim
    1,270
    also * might need to replace sprockets and chains
    adam
    Mar 2005
    Nebraska
    118
    I just talked to the guy and he said it is all stock but when he bought it, it needed rebuilt so it has a new piston. Everything else but the rear tires are stock. He has lost interest and it has sat for 2years but he went out oiled the cylinder and quirted some gas in the plug hole and it started and ran on the 1st kick. It is aways from my house so I may have to wait to go see it.
