Thread: 200x and xr200
    Aug 2002
    Creswell, OR
    889
    200x and xr200
    I am wondering is there a way to cross reference all parts that may interchange. I am looking at all electrical, the cranks and everything else odd. Is there some trick, ie part numbers, or perhaps you have tried? First on list to check compatability is crank, rod, bearings and so on. Pretty much right now inside cases. Oh yeah 85 200x and 87 xr200. Thank you Jen
    P>S What I do know. The kicker shaft are different but everything on the kicker itself is the same. Right down to the one gear that sits on the the shaft. As of right now I have not scoped the transmission, I am too scared I will mix up parts.
    www.3wheeler.org
    * * * Nothing scares me more than someone who knows, with certainty, what is best for me * * *
    Nov 2002
    Kirkville, NY
    3,831
    I go onto bikebandit.com and compare part numbers; it takes a while but works. Maybe we should start a list of interchangeable parts.
    2004 BMW R1150R
    1972 Honda CT 70
    2007 Lifan 110
    Glenn J's Avatar
    Glenn J is offline At The Back Of The Pack Arm chair racerFirst time rider
    Jul 2003
    Wallyword, CT
    155
    Quote Originally Posted by thefox
    Not a bad idea.
    1985 200X
    Aug 2002
    Creswell, OR
    889
    Do you know how much work this is.
    Example crankshaft assembly different. BUT rod, bearing left and right crankshafts all same.
    Rockers same, camshafts different, Cam chain different but same number links (WTF ).
    OIL pump assembly same.
    flywheel and all that jazz different.
    www.3wheeler.org
