Results 1 to 9 of 9
Thread: Removing axle and pivot bearings...
    Lots_Of_Nothing's Avatar
    Upstate NY
    2,665
    I am triyng to get the rear end bearings out of this 350X carrier, and also the swingarm pivot bearings, so far I have only taken steps backwards. I heated the carrier up, and then slide a blunt chisel from the other side and aligned it with the bearing, I smacked it once real hard and the inner race shattered and the balls went everywhere, Now I am stuck with the other race seized in the carrier, I really dont know how in the hell to get it out, as there isnt much space to work with, So I am going to get the dremel and cut the race in pieces and smack it out, Unless someone else has some tips on removing it.
    Next problem is the pivot bearings, again, soaked in a good penetrant and tried pounding out.. Nothing.
    So, it looks like I need some help.
    Aug 2004
    Ab Canada
    4,368
    do you have acess to a hydrolic press? if you dont you can just take it to the local bike shop or what ever and pay 20$ and have them out in 5 min...sometimes thats just easier than trying to cut them out, or just use a chisle and a and wack it real hard...should come out if out if you wack it hard nuff..eh
    1985 Tri-Z-
    Billy Golightly's Avatar
    Live Oak, FL
    15,068
    Get someone with a welder and lay a bead along the race. The heat and weld shrinks it up (Makes it smaller of course) and it will more then likely fall out after that is done. If you dont want to do that, good luck on beating the hell out of it heh.
    Upstate NY
    2,665
    Alright, bearing carrier problem is solved, cut them in half and smacked them out. Now onto the pivot bearings.
    May 2002
    Southeastern Wisconsin
    3,658
    Quote Originally Posted by Lots_Of_Nothing
    If I remember correctly you can drive everything out one end or the other. I think there is a removable spacer tube between the bearings. Find a deep well socket the same size of the bearing with an extention and start driving away. If you don't want to abuse your tools like that then do as said before and spend a couple bucks and get them pressed out.
    VABCH350X is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Aug 2003
    Whidbey Island, WA
    322
    Quote Originally Posted by HondaATC
    This is good gouge! I was left with a hopelessly stuck outer race with smashed inner race. I read this post, ran a bead around the inside, and it tapped out almost effortlessly. Thanks.
    Cheers,
    -Paul
    86 Honda ATC350X
    86 Honda TRX70
    02 Honda TRX400EX
    03 Kawasaki KFX80
    82 Honda CB900F
    Live Oak, FL
    15,068
    Quote Originally Posted by VABCH350X
    Cheers,
    -Paul
    Old trick my dad taught me. Works like a charm everytime Glad it helped you out.
    Jul 2004
    Mud hill. close to water !
    3,658
    I went to princess auto and got a " Blind Bearing Puller " ... a bit costly but man does it ever work well.
    Basically a big slide with a expanding 2 leg pawl ... pretty slick.
    Currently :
    Upstate NY
    2,665
    Quote Originally Posted by bigredhead
    I have 3 different ones. Junk on bearings that were as bad as the ones on this 350. LOL.
