85 Tri-Z's
85 Quad-Z,
85 YT175 For sale,
83 YTM 225DX,
83 YTM 200L For sale,
82 Tri-Zinger 60 For sale,
8? YTZ 80 Conversion,
85 YT 125,
89 Pro Hauler 230,
05 YFZ 450,
99 V-Star,
Yes, the inner cases should be exactly the same. But why do you want to use the YZ sidecase on the Tri-Z? You'll have a backwards kicker then. You can either use the YZ engine and transplant your Tri-Z sidecase and kicker gears over, or use the Tri-Z engine and transplant the powervalve stuff over, all of it can go in a Tri-Z sidecase. You'll need to talk to Neil (Chainsaw) Nathan (03OrangeShee) or Derrick (Derrick Adams) since they have all done it for more detail. I have the stuff to do it but need to get my cylinder sleeved and figure out how to correct the angled intake since I want to use the 85 cylinder.
That is what I was wondering. I have read some where that I can use the YZ side cover as long as I use the Tri Z kick start kear. does that mean thay are not intercahangable? This deal also includes the jug as well. Should I get the jug and head only?![]()
85 Tri-Z's
85 Quad-Z,
85 YT175 For sale,
83 YTM 225DX,
85 YT 125,
89 Pro Hauler 230,
05 YFZ 450,
99 V-Star,
I dont think the YZ sidecase will allow the little cover from the Tri-Z to go on that reverses the direction of the kicker.
You need alot more stuff then just the head and cyl. You need that, plus the powervalve, the covers, the govenoer linkage/rod, the gears out of the YZ sidecase, and a different gear that runs off the crankshaft I believe. I dont know all the exact parts off hand.
I'm sorry, I should have been more specific. I know I need the rest of the parts to make this work. All that is included in the deal. My mane concern was paying for something I do not need. If the side cover can not be used I will save a little money. Thanks for the help! I will contact the guy and let him know what I do and do not need.
85 Tri-Z's
85 Quad-Z,
85 YT175 For sale,
83 YTM 225DX,
85 YT 125,
89 Pro Hauler 230,
05 YFZ 450,
99 V-Star,
So, does that mean I can use the Tri Z kick start gears in the YZ engine?
85 Tri-Z's
85 Quad-Z,
85 YT175 For sale,
83 YTM 225DX,
85 YT 125,
89 Pro Hauler 230,
05 YFZ 450,
99 V-Star,
Originally Posted by LonesomeTriZ
Them and the Tri-Z sidecase yes.
Nice win Louis, I had been watching that engine but more important things came up. Like that shifter it has on there? Haha.
as chainsaw said the tri z gears work in the yz case. i was looking at that engine too, but i ended up getting a different one. all the z's will be powervalved before long.... mine will![]()
1985 Yamaha Tri Z 260PV
Suzuki Trail Buddy 50
I totally agree. The Tri Z is a superior ride in my opinion. Even with the stock motor my 86 is very close to my stock 86 R.
The powerband is broader on the Z and much more versitile....yet it still wants to rev.
The suspension is very close and with 20 inch rear tires...it slides just as good.
Agreed...if Yamaha had done that....
SEND ME PM HERE - CLICK HERE
Dirtbikes:
1988 Yamaha DT
Thanks for all your help. That engine was not the parts lot I was refering to. I decided to go after it at the last minute after watching it for several days. I just wish it was a six speed. Hey, is there a way to change that? I know how to do it in a Tri Z bottom end, would it be the same?
85 Tri-Z's
85 Quad-Z,
85 YT175 For sale,
83 YTM 225DX,
85 YT 125,
89 Pro Hauler 230,
05 YFZ 450,
99 V-Star,
The TRi-Z kickstarter setup is on different by the sidecover.. There is a gear in the sidecover that allows for forward kick. The YZ sidecover does not have the casting for the gear and the kickstart shaft to mount.
As for your transmission, you will have to swap entire transmissions over, the 6 speed trans has 6 gears on the main shaft, the 5 speed only has five. You will have to switch both shafts, shift forks, and shift drum.
My Ride - 2001 Raptor, HotRods 720 Stroker.
94' Banshee- Bing Bing Bing
85 Tri-Z, 6 Speed, Power Valved, Boyesen Reeds, DG Pipe.
Kids - Lil' Yamahas
Summer rides - 1100 Wave Raider, JS550, 06' V-Max
Winter toy - 95' V-max4
i hvae done that with a Tri Z bottom end. It sounds like it will be the same. What year were the YZ's six speed? Would a Tri Z six speed set up fit a YZ bottom end?Originally Posted by diggerzmound
85 Tri-Z's
85 Quad-Z,
85 YT175 For sale,
83 YTM 225DX,
85 YT 125,
89 Pro Hauler 230,
05 YFZ 450,
99 V-Star,
