Originally Posted by
Huffa
Main difference is the 200 diameter from hub to beginning of splines is a lot thicker and like you mentioned, the threaded portion of axle ends & nuts.
Why in the world would they make it weaker on the 225?
Has to be a reason. I'm sure it's exactly the same metal used. At least I think it is?
Well... you got to look at the intended uses of the machines... 200ERN was a utility work trike. Racks and trailer hitch... no suspension too!
The 225DX was more of a sport/trail trike... didn't have to be as 'heavy duty' as the 200 utility plus with some rear suspension, probably less stress on the axle. Less weight for the sport trike too!
'86 ATC350X - 'Go-Go Girl'
'85 ATC70 - All Original
'83 Suzuki ALT125 - Pieces
