On my 84 tecate I had to pull of the clutch cover to repair the clutch and to do that you have to take the kick starter off. I finally got the cover off but the kick starter is still stuck to the shaft. In order to put it back together I have to get the ick starter off of that shaft. It isn't welded on or anything. We have tried heating it up, pounding on it, gear pullers won;t work because you cant get the teeth for the pullers in between the case and the kick starter. Does any one have any ideas? Or had the same problem? Please help me out on this one. thanks
