Results 1 to 15 of 16
Thread: piston help
    Apr 2005
    mason city iowa
    47
    piston help
    i need to knwo where and what i have to get and what kind of piston i can get my klt160a1 need help fast
    kawahonda 3 wheeler
    1988-2002 blaster
    reeds, pipes, wiseco piston, and twist throttle
    Jan 2005
    RI
    2,530
    I'm sorry, I would help you, but I cant decompile the mass of letters which came about after you slammed your hands all over the keyboard. Make it readable, then others will reply.
    Apr 2005
    mason city iowa
    47
    What kind of pistons can i get and where can i get them from for my klt160a1
    kawahonda 3 wheeler
    1988-2002 blaster
    Aug 2004
    Ab Canada
    4,368
    first you have to know what bore your cylinder is on, should be a number stamped in the top of the piston, then call your local kawasaki dealer and order it or check out www.bikebandit.com
    1985 Tri-Z-
    Apr 2005
    mason city iowa
    47
    well the only thing is, is that i can't find any thing for it HELP
    kawahonda 3 wheeler
    1988-2002 blaster
    Apr 2005
    mason city iowa
    47
    come on guys throw me a bone here i need some help i can't find anything for my klt160 i know one of you have to know so come on
    kawahonda 3 wheeler
    1988-2002 blaster
    a-camp's Avatar
    a-camp is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Orange Co.
    420
    Is it some kind of trike?? Or a ray gun? (klt160a1) Not up on them.
    May 2002
    Southeastern Wisconsin
    3,658
    Quote Originally Posted by ras86
    Have you called a dealer yet?
    Jun 2004
    Oregon
    1,782
    Quote Originally Posted by DeePa
    LMFAO...............
    1986 ATC 250R
    Ported w/ Cool head
    LED pipe and silencer.
    Vforce3
    Keihin PWK 38mm
    Works Ultra Cross Shock
    LSR +2 Axle
    American Star Racing +4 Swinger
    LED Intake
    Hi-Flite desert seat
    OEM clutch 89 upgrade
    2021 YFZ450Rse Rossier R5 Titanium Header AIS Delete FCI Vortex ECU
    Apr 2005
    mason city iowa
    47
    Thumbs down
    Quote Originally Posted by Fox250R
    is it soemthign racial because i need some that can help me not someone thats gonna laugh so thanks buddy
    kawahonda 3 wheeler
    1988-2002 blaster
    Bender is offline At The Back Of The Pack Arm chair racerFirst time rider
    Jun 2004
    Chippewa Falls WI.
    234
    You need to find out what the bore size is, you can use a inside mic to measure it
    86 ATC 350X
    86 ATC 200x (my P.O.S.)
    ATC 70 (first trike,7 years old)
    Email: Bender@bodybuilders.com
    Mar 2003
    Barnesville,Ohio
    2,298
    racial...lmao
    1985 Honda 350X - a lot of performance stuff, everything but a cam, hope to get one soon
    1984 Honda 200ES
    198? Yamaha YT60 Tri-Zinger
    TrikeFest '04 & '07 Survivor
    Rittman, Ohio
    6,276
    Its extremely difficult to understand your posts. Try re-reading them before you hit "submit reply".
    You got some good suggestions, but you seem to be ignoring them and looking for a magic solution. Nobody here can tell you what your bore size is. You have to get to the piston and check it for markings. If you cant find read or understand the markings, take the piston out and take it with you to the dealer, and they can either read it or measure it. They will also be able to order you a replacement, whether it be an OEM, or an aftermarket one. Its probably a good idea to take the cylinder in with you as well, so they can check the bore for wear also.
    Apr 2005
    mason city iowa
    47
    please reread it doesn't say anyting about what size it is i just wanted to know a few little questions grandma!
    kawahonda 3 wheeler
    1988-2002 blaster
    Nov 2002
    Kirkville, NY
    3,831
    Let me try this one
    "i need to knwo where" your local Kawasaki dealer or even a independent shop, try bikebandit.com or one of the other online shops listed under "parts" on the main page.
    "and what i have to get" A piston, it is round, you probably want to replace the rings and pin too, maybe even go up a bore size if it is worn out (sorry I can't see inside your engine to know if it needs a bore)
    "what kind of piston i can get my klt160a1 " Well since it is a Kawasaki I would think a Kawasaki piston would be good choice and because the 160 was not a very popular model I don't think there are many aftermarket companies that make one for it. I have not seen a wiesco and proX listed for it.
    2004 BMW R1150R
    1972 Honda CT 70
    2007 Lifan 110
