Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 34
Thread: Nitrous on my Neon...
    Mar 2004
    North Central Ohio!!
    2,712
    I'm finally getting around to installing the nitrous on the Neon this week. Since my Mustang project is at a financial stand still, I'm going to run the Neon in the Sport Compact class this year at the local drag strip.
    I managed to run 15.70's last year on the motor, with the stock 185/70/13's. This season i'm adding the street slicks and a 50 shot of juice. Shooting for mid 14's. Might up to a 75 shot if everything goes well and try for 13's.
    Don't know how many of you guys drag race, but mid 15's is pretty respectable for a 4 banger. I've beaten several of the slower V8 cars. It's pretty fun.
    Aug 2004
    Ab Canada
    4,368
    do you have one of them first style neons that only takes me 30 seconds to break into to go joy ridin in? or the later model...lol
    1985 Tri-Z-
    Aug 2004
    Peoria, AZ
    625
    Not too shabby there Derrick! I've got a 97 N/A Eclipse that I've bolted on almost all I can, no internal motor mods though. I'll bet you don't have the PS or AC on that ride anymore do ya. I'm gonna give up on making a 420A fast though & buy a GSX. I know thats a quick car from the get-go!
    Feb 2005
    Oregon
    772
    Not bad for a 4 banger, but I will stick with my V8, I am shooting to run low 11's.
    1986 310R
    1975 F150 4x4
    1975 F250 4x4
    1968 F100 2wd
    2001 Dodge 1500 4x4
    Aug 2004
    PA
    190
    Here's my 4 banger. High 12's in quarter.
    Us
    727
    What mods do you have on that neon? Thats a real good time for street tires and a 4 banger. Is it auto or manual?I dont really like sport compacts, but at least yours is american.
    Nice bug homemade, whats done to it? I like the looks of bugs when they're lowered like that
    Mar 2004
    2,712
    My car is a SOHC base model. It weighs 2000lb with me in it. It has absolutely no options. No P/S, no A/C, it didn't even come with sway bars. Its the lightest Neon you could get.
    As far as mods, I don't have many. I have an underdrive pulley, ported and polished stock throttle body, Cold air intake, and a full length header with 2 1/2" exhaust.
    That's it. It should be good for 15.50's on the slicks. (Spins real bad with the street tires) I did a little more research on it last night, and it turns out I can spray 75hp with no problems, just need to go to a colder plug and close the gap a little.
    As soon as this engine gives up, I'm putting a 2.4L in it. Should be good for high 12's on the juice and low 14's on the motor.
    Belsano, PA
    1,387
    Good times
    Too bad your Tri-Z wasn't any faster. I know, that isn't funny.
    I got in touch with my buddy, he got the carbs ordered. Oh ya, BTW, I don't want YOU to be able to run away from me, so I ordered me up a new 39 too.
    I got a 65 Beetle sitting here, it would be real fun building a drag car outta it, but gonna make a daily driver instead. It will have a couple go fast items, but not gonna get too crazy with it. My father has a bigbore in his Kharman Ghia..1780cc I believe. It scoots. The guy that built that engine, has a 2500cc stroker...claims it pushes about 225-250 Hp. Gave that a thought, but he said it is too agressive for the street...hard to keep her cool, and gotta chop up the rearend (body) a bit to fit it in.
    Derrick, what put the brakes(financial standstill??) on the 'Stang?
    Mar 2004
    2,712
    Actually, with all the trike projects going on this year, and the baby coming, I decided just to take the year off from the stang. Besides, I'm to the point where I have to drop 6 Large bills on an engine. (I can buy a lot of trikes for that!)
    I'm still trying to get the trail Z together before TF and I want to build my 500R.
    No amount of porting will help you against that bike!
    Aug 2004
    PA
    190
    My bug is in pieces now, I'm building a new motor/trans, etc. When I ran the high 12's I had a 2110cc motor with Weber 48's, an Engle 130 cam, 9 1/2 compression, street eliminator heads with 44 by 38 valves, 1 5/8" merged exhaust, H beam rods, electronic ignition, wicked tight gears, 12" wide cheater slicks, one seat, gutted interior, etc, etc. Right now i'm in the process of building a 2332 with more compression, bigger exhaust, and I shaved a lot of weight off the car. Should be around 1600 lbs when I'm done, and 240 hp. I'm really looking forward to what it will do with the new combo. I just like saying I ran 12's with a 4 cylinder, 30 year old technology, no nitrous, no turbo, no blower car. I'll post some more pictures later if you guys want.
    Anaheim
    1,270
    i have a 68 baja bug was a hard top but converted it and rolled the edges then installed a class 11 cage and took all the metal off i could and replaced with fiberglass, i have a close ration 3 &4 for sand dunes and just all out accelartion i turn about 105 at 4600 RPMS (est.) thats with a 2110 82X90.5 with 40X35.5 intake and exhaust valve heads ported by CB performance, 10:1 compression with total seal rings, i run a 110 cam with 1.25 rockers, i havent done the quarter because i havent had it done long enough and iam still redoing stuff. iam runnin a warior front with 2 1/4 wider trailing arms, with billstein 7100's. when its alld one and i get it to the dunes thanksgiving ill take pics right now its a total sleeper beater (cause it doesnt look like it should be running LOL)
    adam
    86 ATC 500R the duner..
    85 ATC 500R...the not quite finished faster duner
    1985 ATC 250R Bone stock!!
    1985 ATC250R mx/duner
    1986 TRX370R MX/Duner
    94 Banshee 400PV Cheetah 105RWHP
    Phoenix, AZ.
    6,719
    Quote Originally Posted by AZ250R
    I'm probably having a brain fart but what is N/A?
    I had a dark gray '97 GST until a couple years ago. Fun little cars. I miss it.
    wheelie king's Avatar
    wheelie king is offline Aficionado of white surprise sauces. Arm chair racerRoostin Away
    Central FL USA
    1,174
    NA = Normally Aspirated (non turbo or Nos)
    My old 93 stang had a 100 shot NOS fogger kit, among other things, and the bottle made all the difference. Best mod I made in the long run.
    1986 Honda ATC 200 S
    Some quads and a S x S
    Supporter of Uncle Rico's football camp. Since 1982.
    If you are reading this in English, thank a U.S. Military VET. ΜΟΛΩΝ ΛΑΒΕ
    May 2002
    Southeastern Wisconsin
    3,658
    Quote Originally Posted by wheelie king
    N/A = naturaly aspirated
    Mar 2004
    2,712
    Got the system installed today. Now I just need to wire it all up!
