Page 2 of 2 FirstFirst 1 2
Results 16 to 18 of 18
Thread: 250 sx swingarm bearing help
    kdagenais is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Aug 2003
    254
    Quote Originally Posted by Waznyk
    kdagenais your absolutely right. the shaft slid back very easily and the whole assembly is off(swingarm) now i'm tackling a stubborn rusted race. will try some heat and maybe a good chisel if it starts to get chewwed i'll have to invest in a bearing puller, thanks alot, i sure appreciate the help. well off to the race!!!
    Trty the dremel theory worked great for me. Once you spilt it on one spot popped right out. Blind bearing puller would be good to I am sure depending on how wore out the race is. Mine the race was so worn there wasn't anything to get a hold of.
    Good Luck and keep us posted on the progress.
    Mar 2005
    overton, PA
    5,257
    i just slid the yoke of fthe output shaft on everyone of my sx's and es's and * can slid eit down its on a sprign andonc ei get that far the whole swingarm will come out enough and just rotate the brake side hub clockwise and it will slide right out.
    Apr 2005
    Alberta, Canada
    4
    well it's done, i changed both bearings, they were the same, i popped them out by getting behind them going through the opposite side, it all went quite smoothly, thanks for all the help!
