Results 1 to 7 of 7
Thread: need advise
    Jun 2003
    203
    need advise
    i have a 110 that i have been tinkering with now for about a week and i got it running. i need some advise as to why it will run good from an idle to midrange but when i give it full it seems like it runs out of fuel. it runs alright with the choke on. ive tried two different carbs and i get the same result. i was wondering, if the intake gasket is leaking would it show up as a leak during idle? i sprayed brake clean on the intake gasket and it didnt seem to do anything, but that was at idle. i didnt try it with more throttle.
    thanks
    tyler
    if a vegiterian bites their lip, do they feel guilty?
    yep, thats our man. he pulled himself into an airduct. he must have worked out for months!
    84 200x bored 50 over and pipe(more in the works)
    76 ke 175 lookin like a kd 125
    http://mysite.verizon.net/res216cg
    Mar 2003
    Barnesville,Ohio
    2,298
    check your air filter. make sure it and the hose that runs from the airbox to the carb are clean
    1985 Honda 350X - a lot of performance stuff, everything but a cam, hope to get one soon
    1984 Honda 200ES
    198? Yamaha YT60 Tri-Zinger
    TrikeFest '04 & '07 Survivor
    Jun 2003
    203
    it has a new air filter. ill have to mess with it some more on sunday
    Aug 2004
    Ab Canada
    4,368
    what size of main jet is in the carbs your using?
    1985 Tri-Z-
    Jun 2003
    203
    im not really sure. im assuming its the stock jet since this three wheeler has been around the farm since new.
    m
    23
    How can you tell the size of the jets and which one is which?
    Jan 2005
    RI
    2,530
    Its stamped on it...I'm thinking your petcock on the tank is filled with rust or crud, making the gas flow into the carb bowl slower, not gi ving you enough gas at full throttle...Check the tank for rust and make sure the carb is clean, and youll be good to go.
