Thread: Chain questions
    Feb 2005
    Arizona
    94
    Chain questions
    On the newest family member I don't see a chain tensioner, Does the 185 have one?
    I also wondered what kind of oil you should use to lube the chain?
    And lastly, I was wondering how much slack is normal / advised?
    This bike has about 2" of slack in it and no way I can see to adjust it.
    79' Honda 110
    82' Honda 110
    82' Honda 185s
    84' 200es Big Red
    85' 250es BigRed
    Jun 2003
    South of Rochester, NY
    3,470
    What's the "newest" family member? All I see is a Shaft Drive Big Red in your avatar! EDIT - Oops.... getting late... I assume its a 185? See bolded part below...
    Depending on the trike, look for either a concentric rear bearing carrier for the axle that will rotate and extend the distance between the sprockets.(350X, later 250R's) Another way to adjust is the swingarm bolt adjusts forward and back (81-82R, 200X). Seems like my 82-83 Big Red had 4 bolts you loosened that held the rear axle carrier, then you adjusted a bolt with 2 lock nuts that helped pivot the rear axle housing backwards. Try looking for any of these ways to adjust your chain..... or even better.... find yourself a owner's manual or a repair manual! Good luck man!
    Bruce
    '86 ATC350X - 'Go-Go Girl'
    '85 ATC70 - All Original
    '83 Suzuki ALT125 - Pieces
    Aug 2004
    Ab Canada
    4,368
    there should be a tensinor on the bottem right bolt that holds the carrier to the frame of the bike, to tighten the chain you have to losen all 4 bolts then use the tensinor to set the tension which should be between 10-20mm or 0.4-0.8 in, thats mesuring from the top of the chain and lifting it up...hope this helps
    1985 Tri-Z-
    Feb 2005
    Arizona
    94
    Thanks guys, I helps alot.
    I have tried to get numerous manuals on ebay but keep losing them since I work alot and cant seem to stay on top of the bidding. Nobody sells them around here and to get one I have to travel to Phoenix which is about 125 miles to the Honda shop.
    79' Honda 110
    82' Honda 110
    82' Honda 185s
    84' 200es Big Red
    85' 250es BigRed
    Aug 2004
    Ab Canada
    4,368
    use www.esnipe.com works good and you dont gota be around to win the auction!
    1985 Tri-Z-
    ATCnut is offline Got The Holeshot Arm chair racerJust too addicted
    Nov 2002
    Auburn Washington
    799
    Or just go the www.helminc.com and buy the manual. You might pay a couple of more bucks than ebay, but you will have it sooner.
    ATCnut
    82 185s - sold
    83 200x (hopped up)
    84 200x (stock)
    84 70 (lost this one to the DMV)
    85 70 (soon to have lights, a foot brake, and CDI ignition)
    84 200es (parts trike) - sold
    85 350X (the best)
    85 350X (siezed motor, dream of a poweroll kit someday)
    85 250sx (frame was trash, got parted out)
    86 250sx (the tractor)
    86 250sx (a nicer tractor)
    86 250sx (an even nicer tractor)
    87 200x (parts trike, its really rough, a dog was chewing on it for a while)
    87 250es Big Red (the tank!!)
