Thread: Jetting My Z to The Pipe???????
    Jan 2005
    Southeast MO.
    84
    Hey i added this pipe to a fresh top-end and it seems to wanna try to drowned out taking off. I have a dial a jet and it runs awesome after i get revved up a bit. What could be the problem? And should i lean the carb to get better use of the dial a jet. I thought maybe i could drop the needle a notch to lean it up and let the dial a jet fill in the gaps for me. What you guys think?????????
    85 Tri Z 250
    Boyesen Power Reeds
    +4 Westcoast Swinger
    6 speed tranny
    Drag ported & polished
    Pro Lite Piston
    DG Nationals Pipe
    Too many small mods too list.............
    Jun 2004
    geraldton, west australia
    1,068
    yes, with the dial a jet, * are mean to go down a few main jet sizes and also lean it out a bit. there is a fairly recent thread about the dial a jet setup.
    LIVELOVERIDEDIE
    1981 Honda Atc 124R-Racer project
    2005 Giant STP 1- rollin' on 26's
    Jun 2004
    1,068
    LIVELOVERIDEDIE
    Mar 2004
    North Central Ohio!!
    2,712
    Welcome to aftermarket pipes on the Tri-Z. Most pipes are designed to increase mid to top end power. Your low end loss may just be a side effect of the pipe you used.
