Results 1 to 7 of 7
Thread: 200e hubs..do others fit?
    Nov 2004
    Minnesota
    4
    Since I can't seem to find any after-market rims for my Big Red,
    (150mm X 4 bolt pattern) Will other hubs fit the splines on my axle?
    Seems multiple other bolt patterns can be found.
    Thanks in advance!!
    SeanO
    Jun 2004
    geraldton, west australia
    1,068
    it seems logical 200x hubs will fit
    LIVELOVERIDEDIE
    1981 Honda Atc 124R-Racer project
    2005 Giant STP 1- rollin' on 26's
    Nov 2004
    Minnesota
    4
    The 200x has a 110mm bolt circle but are the axle splines the same?
    Could someone measure their shaft diameter (not a pun)
    and count the splines? I'd like to get rid of the rusty originals.
    Thanks again.
    Sean
    Dave223 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Aug 2004
    Houma Louisiana
    388
    hey, dunno if its the same, but I put 250r hubs on my 200, now Im running 300ex quad hubs..they have the same spline count and are 4/110 bolt pattern too and make it 1 1/2" wider. I may be wrong but I beleive from a 125 to the 350x are all the same spline..or up to the 250r. Dave
    Feb 2005
    Binghamton, NY
    113
    check out the white bros. catalog:
    http://www.whitebros.com/04catalog/ATVWheels.pdf
    and you'll see that most atcs are 24 spline. The 350X and newer 250R are 25 spline. I've got a 200s, and found that 200x hubs fit mine. That means any 24 spline Honda hubs should fit, so I bought a set of 400ex hubs on ebay for $25. You can buy a complete wheel/tire set with the 4x110 pattern for about what it would cost to buy tires and then have them mounted. More wheel options in 4x110mm also, as you've found.
    So I'd say look on ebay for 300ex, 400ex, 250R (pre '85) or 200x hubs. There are usually a few 400ex and 300ex hubs going for decent prices. Then you can mount some nicer rims that fit 4x110.
    '84 200s
    '86 BW80
    '02 CRF450
    '89 ZX750R
    Nov 2004
    Minnesota
    4
    Thanks for the help!!
    83200e's Avatar
    83200e is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Aug 2004
    Arkansas
    356
    Trx hubs will also fit,but will give you a different bolt pattern.
