Results 1 to 15 of 16
Thread: NEED HELP QUICK!!! fork seals!!!
    Power_Ram100's Avatar
    Power_Ram100 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Jul 2004
    Kent, Washington
    152
    Exclamation NEED HELP QUICK!!! fork seals!!!
    Im trying to change the seals on my tri z fork. I took all the insides out including the dampener rod. The inner fork leg wont come out of the outter fork leg. Are they suppose to come out?? And how do i get the seal off?? I dont know what to do from here. Thanks for your help
    Matt
    I just thought of something funny...your mother
    83 Big Red with Bear Claws (SOLD)
    85 Tri Z with Maxxis Alltrax rear tires on .190 aluminum rims, DG pipe, Answer SA Pro silencer, High Flow Fuel Pump, and UNI air filter (SOLD)
    99 Yamaha Kodiak 400 4x4 with Warn winch and custom skidplates
    85 Honda 250 SX with Dirt Devils (near mint) (SOLD)
    May 2003
    Houston, Texas
    2,409
    Did you loosen and remove the allen bolt on the bottom of the fork leg?
    I guess you did cause you took out the damping rod.
    SEND ME PM HERE - CLICK HERE
    Dirtbikes:
    1988 Yamaha DT
    Jul 2004
    Kent, Washington
    152
    YES, i took the bolt out at the bottom of the fork leg
    Mar 2003
    West Monroe, LA
    847
    You need to put your forks in a vise but be careful not to over tighten, then slide the inner tube in and snatch it back tawords you and the seals. After a few tries the seals and the inner tube should pop right out. Oh by the way make sure you have removed the seals snap ring.
    86Honda250R
    85Honda250R Sold
    82Honda250R
    Tiger 200 198? Sold
    Tiger 250 198?
    Tiger 80 (need engine) Sold
    85 Tri-Z
    86 Tecate
    Perfection consists not in doing extraordinary things, but in doing ordinary things extraordinarily well.
    Jul 2004
    Kent, Washington
    152
    THANKS A BUNCH GUYS!!!! i got them apart!!!!!!
    May 2003
    Houston, Texas
    2,409
    did you pull them apart by hand or lock them in vice. I was wondering because I have to do the same with my Z and don't have a vice.
    Dirtbikes:
    1988 Yamaha DT
    TRI Z Racer's Avatar
    TRI Z Racer is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Dec 2002
    Boscawen, NH
    342
    what did it cost you for parts? where did you get them? i gotta do it soon too
    1985 Yamaha Tri Z 260PV
    Suzuki Trail Buddy 50
    Aug 2002
    NY
    2,652
    just pull the tube out of the bottom part by hand i just rebuilt my 86 tri-z forks. it was a snap. took all of 10 minutes took longer for them to drain lol i bought new seals from dennis kirk.
    Jul 2004
    Kent, Washington
    152
    I yanked them apart. I got the fork seals from http://www.rockymountainatv.com/ #0151439E Fork Seals, K & L, Yamaha Tri-Z 250 85 $8.99 Im gonna have to buy some PVC pipe to seat the seals and some fork oil. What kind of oil is good to use and how much goes in each leg?
    Mar 2003
    West Monroe, LA
    847
    ATF fluid is what most people use. Im not sure on how much fluid per fork, i dont have my manual with me.
    86Honda250R
    85Honda250R Sold
    82Honda250R
    Tiger 200 198? Sold
    Tiger 250 198?
    85 Tri-Z
    86 Tecate
    Jul 2004
    Kent, Washington
    152
    Exclamation New Problem
    OK now i have a new problem i put the new seal in about 1/2 way when remembered that i didnt put in the Taper Spindle. So i yanked everything out but the metial slide didnt come out. It stayed inside the fork leg. Now i cant get the medal slide out and cant get the inner leg in. Any ideas how i can get the metal slide out. Ive tried everyting i can think of but its jammed in there pretty good. You can see from the picture that the inner silver ring is stuck in there.
    Jan 2005
    Great Bend
    704
    to tell ya the truth that fork is still damn dirty on the inside. the cleaner the better. better operation and better re-assembly. as for stuck parts, get a propane torch and heat that are of the fork tube up and it should pop out
    May 2003
    Houston, Texas
    2,409
    Geez I hope somone figures it out cause I dont have a torch.
    Dirtbikes:
    1988 Yamaha DT
    Jan 2005
    Great Bend
    704
    stick it in the oven at 350 degrees for about 15-20 minutes, that'll get it hot enough. LOL
    Jul 2004
    Kent, Washington
    152
    I screwed up the teflon like coating on both the metal slides. I guess forcing it dosent work in this case. So tommrow im gonna use the dremel to cut out the stuck medal slide. I have already ordered a new medal slides.
